Clear all data points in a feed?
by breckymorris on Mon May 11, 2020 5:25 pm
I've seen a number of posts inquiring about removing all data from a feed but keeping the feed, but I've never seen it answered. Is there a way to do it via GUI or from a command line (via curl, for example)?
It comes up frequently for me - like I make a change to the program and then I have all this stale data and the plot scale is goofy or I move the sensor from testing into 'production' and the same thing happens. Removing the entire feed and recreating it isn't convenient.
Brecky
breckymorris
Re: Clear all data points in a feed?
by brubell on Tue May 12, 2020 10:32 am
Hi Brecky,
There's no way to remove all data from a feed at once. Feed deletion is an API action (https://io.adafruit.com/api/docs/#delete-data-point) and is therefore limited to your account's data rate (30 or 60 data points per minute for IO Free and IO Plus, respectively).
You may want to create a script which uses the delete data point api endpoint (https://io.adafruit.com/api/docs/#delete-data-point) to remove data.
I'll put a feature request in for the devs., it's something I'd like to see too.
- Brent R.
brubell
by alanspearson on Sat Feb 06, 2021 5:44 pm
I'd love to have this feature too. I have a feed in which the sensor was not correctly connected for a while and it now has a bunch of invalid data. It is throwing off the charts now, and I'd like to just reset the feed to empty. I could delete the feed but I guess it would probably remove it from my dashboards.
alanspearson
by stanrock on Fri Feb 12, 2021 10:16 am
Found a workaround for clearing all data from a feed. Go to your feeds and delete all of them related to your sketch. Wait for your update period and magically, your feeds will re-appear!
From what I have observed, there is no need to re-create your feeds, them seem to be in the system even after you delete them.
stanrock
by brubell on Fri Feb 12, 2021 10:50 am
stanrock wrote:Found a workaround for clearing all data from a feed. Go to your feeds and delete all of them related to your sketch. Wait for your update period and magically, your feeds will re-appear!
The Adafruit IO Arduino library can programmatically create feeds from your sketch, if they do not already exist on your IO account.
brubell
by stanrock on Fri Feb 19, 2021 5:12 pm
Thats a sweet feature! Gotta love Adafruit.
stanrock
