Clear all data points in a feed?
by breckymorris on Mon May 11, 2020 5:25 pm
I've seen a number of posts inquiring about removing all data from a feed but keeping the feed, but I've never seen it answered. Is there a way to do it via GUI or from a command line (via curl, for example)?
It comes up frequently for me - like I make a change to the program and then I have all this stale data and the plot scale is goofy or I move the sensor from testing into 'production' and the same thing happens. Removing the entire feed and recreating it isn't convenient.
Thanks,
Brecky
breckymorris
Re: Clear all data points in a feed?
by brubell on Tue May 12, 2020 10:32 am
Hi Brecky,
There's no way to remove all data from a feed at once. Feed deletion is an API action (https://io.adafruit.com/api/docs/#delete-data-point) and is therefore limited to your account's data rate (30 or 60 data points per minute for IO Free and IO Plus, respectively).
You may want to create a script which uses the delete data point api endpoint (https://io.adafruit.com/api/docs/#delete-data-point) to remove data.
I'll put a feature request in for the devs., it's something I'd like to see too.
- Brent R.
brubell
