MQTT connection and client.check_msg() problem
by rodrigo1120 on Thu May 14, 2020 2:36 pm
I'm using Adafruit IO switches to turn my nodeMCU lights ON and OFF. The following code works but for a limited period of time. 5 minutes after the connection into Adafruit IO it seems the client tries to reconnect and if this happens I lose my switch funcionality at my adafruit dashboard. Either if I try to turn on or off the LED on my dashboard, the nodeMCU does not responds accordingly. Here is the code used (I'm using micropython, pycharm and a Lolin v3 nodemcu)
from machine import Pin
import sys
import os
import network
from umqtt.robust import MQTTClient
random_num = int.from_bytes(os.urandom(3), 'little')
mqtt_client_id = bytes('client_' + str(random_num), 'utf-8')
ADAFRUIT_LINK = b'io.adafruit.com'
ADAFRUIT_USERNAME = b'rodrigo1120'
ADAFRUIT_KEY = b'AAAAAAAAAAAAAAAAAAAAAAAAAAAA'
ADAFRUIT_FEEDNAME1 = b'gpio16'
ADAFRUIT_FEEDNAME2 = b'gpio2'
ssid = "WIFIUSERNAME"
password = "WIFIPASSWORD"
client = MQTTClient(client_id= mqtt_client_id,
                    server= ADAFRUIT_LINK,
                    user=ADAFRUIT_USERNAME,
                    password=ADAFRUIT_KEY)
mqtt_feedname1 = bytes('{:s}/feeds/{:s}'.format(ADAFRUIT_USERNAME, ADAFRUIT_FEEDNAME1), 'utf-8')
mqtt_feedname2 = bytes('{:s}/feeds/{:s}'.format(ADAFRUIT_USERNAME, ADAFRUIT_FEEDNAME2), 'utf-8')
def connect_to_ap():
    wlan = network.WLAN(network.STA_IF)
    wlan.active(True)
    if not wlan.isconnected():
        print('Connecting to {}'.format(ssid))
        wlan.connect(ssid, password)
        while not wlan.isconnected():
            pass
    print('Credentials: ', wlan.ifconfig())
    try:
        client.connect()
    except Exception as e:
        print('Could not connect to MQTT Server {}{}'.format(type(e).__name__, e))
def callback_routine(feed, msg):
    print('Received Data from: feed={}, msg={}'.format(feed, msg))
    if ADAFRUIT_FEEDNAME1 in feed:
        action = str(msg, 'utf-8')
        if action == 'ON':
            pin16.value(0)
        else:
            pin16.value(1)
        print('Action: {}'.format(action))
    if ADAFRUIT_FEEDNAME2 in feed:
        if action == 'ON':
            pin2.value(0)
        else:
            pin2.value(1)
pin16 = Pin(16, Pin.OUT)
pin2 = Pin(2, Pin.OUT)
pin16.value(1)
pin2.value(1)
def main():
    connect_to_ap()
    while True:
        client.set_callback(callback_routine)
        client.subscribe(mqtt_feedname1)
        client.subscribe(mqtt_feedname2)
        try:
            client.wait_msg()
        except KeyboardInterrupt:
            print('Ctrl+C pressed, exiting')
            client.disconnect()
            sys.exit()
if __name__ == '__main__':
    main()
Here is a picture of my serial monitor with this problem: (I took this picture 15 minutes after I stopped using the adafruit IO switches)
rodrigo1120
Re: MQTT connection and client.check_msg() problem
by brubell on Fri May 15, 2020 10:08 am
Does the monitor page: io.adafruit.com/monitor, show a disconnection after five minutes?
brubell
by rodrigo1120 on Sat May 16, 2020 10:09 pm
brubell wrote:Does the monitor page: io.adafruit.com/monitor, show a disconnection after five minutes?
Yes! after using for some time the switch, this happens: (client_16645810)
Firstly I connected at 22:55:14, then it got disconnected out of nowhere, In the picture you can see i'm using the switches until it stopped working
adafruit problemmmmm.png (90.36 KiB) Viewed 84 times
rodrigo1120
by brubell on Mon May 18, 2020 10:18 am
After you initialize your client, could you enable uMQTT's debugging messages:
# Print diagnostic messages when retries/reconnects happens
c.DEBUG = True
and paste the output here?
brubell
by rodrigo1120 on Mon May 18, 2020 2:38 pm
Here is the debug as needed
adafruit com4 error.png (24.66 KiB) Viewed 78 times
rodrigo1120
by rodrigo1120 on Tue May 26, 2020 1:24 pm
anyone got the same issue?
rodrigo1120
