Error on the IO documentation -- where to report issues?
phord
Post by phord »
I don't see any place to report problems on the Adafruit IO Documentation pages. Maybe a link should be added there on the FAQ. (I tried the github repos, but can't find it.)
On the Services > Time page, the time/iso at https://io.adafruit.com/phord/services/time has the wrong description for the ISO-8601 API. It shows the description for the seconds API instead.
/time HTTP API
GET /api/v2/time/seconds
Get the current time in Unix epoch seconds.
GET /api/v2/time/millis
Get the current time in Unix epoch milliseconds.
GET /api/v2/time/ISO-8601
phord
Re: Error on the IO documentation -- where to report issues?
Post by phord »
There is also a bug in the Jupyter notebook here:
https://hub.gke.mybinder.org/user/brent ... rial.ipynb
In this code:
try:
    test_feed = aio.feeds('test-feed')
except RequestError: # Doesn't exist, create a new feed
    test_feed = Feed(name='test-feed')         #<-- This line
    test_feed = aio.create_feed(test)
The first assignment in the `except` should be `test`, not `test_feed`.
[/code]
test = Feed(name='test-feed')
[/code]
brubell
Learn User Page
Post by brubell »
Hi there,
The Adafruit IO Documentation is hosted publicly on GitHub here: https://github.com/adafruit/Adafruit_IO_Documentation
You can submit an issue for this documentation (https://github.com/adafruit/Adafruit_IO ... ion/issues) with a description of the error. You could also fix the erroneous text and submit a pull request (https://github.com/adafruit/Adafruit_IO ... tion/pulls). Either would be appreciated :)
Could you submit an issue or pull request to this repository directly: https://github.com/adafruit/adafruit_io ... ter/issues. Thanks.
- Brent R.
phord
Post by phord »
Thanks for the pointer to the repos. I sent a pull-request for the Jupyter page bug.
But I already checked in the Adafruit_IO_Documentation repo, and the other bug is not there.
That repo contains the documentation source for https://io.adafruit.com/api/docs/.
The bug I am reporting is found on the IO Services page itself. For example, https://io.adafruit.com/brubell/services/time
For example, the "Time Service" web page says this at the top:
    Adafruit IO always knows what time it is...
But that message does not appear anywhere in the Adafruit_IO_Documentation repo.
    git/opc/Adafruit_IO_Documentation(master)» git grep knows
It's not a huge problem, but it's clearly a mistake and I wanted to point it out to someone. But I still can't find the source for it. :-\
brubell
Learn User Page
Post by brubell »
Hi Phord,
I filed a request to fix the /services/time page documentation to our internal bug tracker. Thanks for reporting this. I also suggested that we break out the services documentation to the public API documentation
brubell
Learn User Page
Post by brubell »
Hi Phord,
This has been updated on the webpage.
