Trouble with MotorHAT and Adafruit IO on RPI3
by ACaldwell8814 on Wed May 27, 2020 6:39 pm
Hello all,
I'm very new to all of this and super excited to try to make some things that are useful. I had a concept of powering a couple of stepper motors with my Adafruit MotorHAT (on top of a Raspberry PI 3) and saw a project to control them wirelessly. I've followed a few guides and installed all of the libraries, and configured all of my settings a few times, but when I run the program and then go to click a go button on my dashboard, my stepper motor will start to work and then stop. I keep getting the following when I run my program, Adafruit_IO_steppers:
File "adafruit_io_steppers.py", line 104, in <module>
stepper_1_step_size = aio.receive(feed_step_1_step_size.key)
File "/usr/local/lib/python3.7/dist-packages/Adafruit_IO/client.py", line 216, in receive
return Data.from_dict(self._get(path))
File "/usr/local/lib/python3.7/dist-packages/Adafruit_IO/client.py", line 118, in _get
self._handle_error(response)
File "/usr/local/lib/python3.7/dist-packages/Adafruit_IO/client.py", line 108, in _handle_error
raise RequestError(response)
Adafruit_IO.errors.RequestError: Adafruit IO request failed: 404 Not Found - not found - API documentation can be found at https://io.adafruit.com/api/docs
Here is my code:
'adafruit_io_steppers.py'
Example of using CircuitPython and
Adafruit IO to control two stepper
motors over the internet.
Dependencies:
    - Adafruit_Blinka
        (https://github.com/adafruit/Adafruit_Blinka)
    - Adafruit_CircuitPython_MotorKit
        (https://github.com/adafruit/Adafruit_CircuitPython_MotorKit)
    - Adafruit_IO_Python
        (https://github.com/adafruit/Adafruit_IO_Python)
# Import Python Libraries
import time
import atexit
import threading
# import Adafruit IO REST client.
from Adafruit_IO import Client, RequestError
# Import CircuitPython Libraries
from adafruit_motor import stepper as STEPPER
from adafruit_motorkit import MotorKit
# Set to your Adafruit IO key.
# Remember, your key is a secret,
# so make sure not to publish it when you publish this code!
ADAFRUIT_IO_KEY = '[deleted before posting]'
# Set to your Adafruit IO username.
# (go to https://accounts.adafruit.com to find your username)
ADAFRUIT_IO_USERNAME = '[deleted before posting]'
# Create an instance of the REST client.
aio = Client(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
# Delay between checking for `go` button press on Adafruit IO, in seconds
ADAFRUIT_IO_DELAY = 1
# Stepper 1 Adafruit IO Feeds
feed_step_1_steps = aio.feeds('stepper1steps')
feed_step_1_direction = aio.feeds('stepper1direction')
feed_step_1_step_size = aio.feeds('stepper1stepsize')
# Stepper 2 Adafruit Feeds
feed_step_2_steps = aio.feeds('stepper2steps')
feed_step_2_direction = aio.feeds('stepper2direction')
feed_step_2_step_size = aio.feeds('stepper2stepsize')
# Steppers start button
feed_steppers_status = aio.feeds('stepperstart')
# create a default object, no changes to I2C address or frequency
kit = MotorKit()
# create empty threads (these will hold the stepper 1 and 2 threads)
# pylint: disable=bad-thread-instantiation
st1 = threading.Thread()
st2 = threading.Thread()
# recommended for auto-disabling motors on shutdown!
def turnOffMotors():
    kit.stepper1.release()
    kit.stepper2.release()
atexit.register(turnOffMotors)
stepstyles = [STEPPER.SINGLE, STEPPER.DOUBLE, STEPPER.INTERLEAVE, STEPPER.MICROSTEP]
def stepper_worker(stepper, numsteps, direction, stepper_name, style, show_steps=False):
    print("Steppin!")
    stepper_steps = numsteps
    print(stepper_steps)
    for _ in range(numsteps):
        stepper.onestep(direction=direction, style=style)
        if show_steps: # print out the steps and send to IO stepper slider
            stepper_steps -= 1
            print('Steps: ', stepper_steps)
            aio.send(feed_step_1_steps.key, stepper_steps)
            time.sleep(0.5)
    print("{0} Done Stepping".format(stepper_name))
    # Reset slider on dashboard
    if stepper_name == "Stepper 1":
        aio.send(feed_step_1_steps.key, 0)
    elif stepper_name == "Stepper 2":
        aio.send(feed_step_2_steps.key, 0)
while True:
    try: # attempt to poll the stepper status feed
        print('checking for GO button press...')
        stepper_start = aio.receive(feed_steppers_status.key)
    except RequestError.ThrottlingError:
        print('Exceeded the limit of Adafruit IO requests, delaying 30 seconds...')
        time.sleep(30)
    # Stepper 1
    if not st1.isAlive() and int(stepper_start.value):
        stepper_1_steps = aio.receive(feed_step_1_steps.key)
        stepper_1_steps = int(stepper_1_steps.value)
        if stepper_1_steps > 0: # stepper slider is set
            # Get stepper configuration from io feeds
            stepper_1_direction = aio.receive(feed_step_1_direction.key)
            print('Stepper 1 Configuration')
            print('\t%d steps' % stepper_1_steps)
            print('\tStep Size: ', stepper_1_step_size.value)
            print('\tStepper Direction: ', stepper_1_direction.value)
            # Set Stepper Direction
            if stepper_1_direction.value == 'Forward':
                move_dir = STEPPER.FORWARD
            elif stepper_1_direction.value == 'Backward':
                move_dir = STEPPER.BACKWARD
            # Stepper 1 Thread
            st1 = threading.Thread(target=stepper_worker, args=(kit.stepper1,
        stepper_1_steps,
        move_dir,
        "Stepper 1",
        stepstyles[STEPPER.SINGLE],))
            st1.start()
    # Stepper 2
    if not st2.isAlive() and int(stepper_start.value):
        stepper_2_steps = aio.receive(feed_step_2_steps.key)
        stepper_2_steps = int(stepper_2_steps.value)
        if stepper_2_steps > 0: # stepper slider is set
            stepper_2_direction = aio.receive(feed_step_2_direction.key)
            stepper_2_step_size = aio.receive(feed_step_2_step_size.key)
            print('Stepper 2 Configuration')
            print('\t%d steps' % stepper_2_steps)
            print('\tStep Size: ', stepper_2_step_size.value)
            print('\tStepper Direction: ', stepper_2_direction.value)
            if stepper_2_direction.value == 'Forward':
            elif stepper_2_direction.value == 'Backward':
            # Stepper 2 Thread
            st2 = threading.Thread(target=stepper_worker, args=(kit.stepper2,
        stepper_2_steps,
        move_dir,
        "Stepper 2",
            st2.start()
    # delay polling the `go button` to avoid Adafruit IO timeouts
    print('Delaying for {0} seconds...'.format(ADAFRUIT_IO_DELAY))
    time.sleep(ADAFRUIT_IO_DELAY)
I'm very inexperienced with most of this software, but I could use some help if anyone out there might be gracious enough to provide it.
Cheers!
-Aaron
ACaldwell8814
Re: Trouble with MotorHAT and Adafruit IO on RPI3
by adafruit_support_carter on Wed May 27, 2020 7:47 pm
It looks like you are having a basic connection issue with Adafruit IO
Have you managed to get a basic Adafruit IO example to work yet? Something without the stepper. Just a basic hello world example.
by ACaldwell8814 on Thu May 28, 2020 10:53 am
Thank you for your reply!
No, I haven't tried any other examples. I downloaded the example repository yesterday. I'll have to see if I can find one to use. Thanks again!
ACaldwell8814
by ACaldwell8814 on Fri May 29, 2020 9:15 am
I gave an example script a try and was successful. I also deleted my older feeds and created newer feeds in case I may have had typos. It is important to note, I only have one stepper motor attached to my motorHAT rather than 2. It is in the stepper1 slot. I created feeds for the second motor for continuity, and I assumed the code would work as long as I'm not trying to perform functions that require motor 2. I wonder if that might be part of the problem.
ACaldwell8814
by brubell on Fri May 29, 2020 10:23 am
Did you set up all the feeds listed on this page?
https://learn.adafruit.com/wireless-ste ... -3019075-2
brubell
by ACaldwell8814 on Fri May 29, 2020 11:01 am
Yes, I did. Those were the feeds I created, deleted, and then created again.
ACaldwell8814
by ACaldwell8814 on Mon Jun 01, 2020 11:06 am
I tried running the temperature sample, and believe it worked normally. There was a new feed added, and data looked like it was being collected with action on the RPI. I think it was working. One thing I'm curious about is whether or not the RPI works out of the box to communicate to IO or if there are any settings I might have missed with the WiFi connection when setting everything up. When I press a button on the dashboard, nothing happens, but if I hold it, the stepper motor twitches, and then the error occurs.
ACaldwell8814
by brubell on Mon Jun 01, 2020 11:08 am
Do you see any errors on the io.adafruit.com/monitor page when you hold the button on the dashboard?
brubell
by ACaldwell8814 on Mon Jun 01, 2020 11:35 am
I do not.
ACaldwell8814
by ACaldwell8814 on Mon Jun 01, 2020 12:21 pm
I believe I might not be connected properly. I don't see any connections listed on the monitor page either.
ACaldwell8814
by ACaldwell8814 on Thu Jun 04, 2020 2:16 pm
Are there any good guides I might use to double-check my setup beyond the project guide?
ACaldwell8814
