connection error code
by cbfraser on Sat May 30, 2020 5:21 pm
a client that was working now on startup cycles through connect/subscribe/disconnect for about 17 iterations and then fails with the connect with error code 6. Where can I find the error codes and thus work out a recovery. And is it possible to find why the disconnect happens, because that triggers the multiple reconnects and subscriptions that eventually cause the code 6 rejection. The monitor page shows the connect/disconnect sequence but no errors.
Sometimes the client connects successfully and can go 12 hours or more - then rapid disconnect/connect followed by code 6
cbfraser
Re: connection error code
by Systembolaget on Sun May 31, 2020 7:47 am
Depends on which connection you're referring to...
Adafruit WiFiNINA fork error codes:
// WL_NO_SHIELD = 255
// WL_IDLE_STATUS = 0
// WL_NO_SSID_AVAIL = 1
// WL_SCAN_COMPLETED = 2
// WL_CONNECTED = 3
// WL_CONNECT_FAILED = 4
// WL_CONNECTION_LOST = 5
// WL_DISCONNECTED = 6
Adafruit MQTT fork error codes:
case 1: Serial.println("Wrong protocol"); break;
case 2: Serial.println("ID rejected"); break;
case 3: Serial.println("Server unavailable"); break;
case 4: Serial.println("Bad username/password"); break;
case 5: Serial.println("Not authenticated"); break;
case 6: Serial.println("Failed to subscribe"); break;
default: Serial.println("Connection failed"); break;
Systembolaget
