Can't connect Feather M0 WiFi to Adafruit IO
by jrwst36 on Mon Jun 01, 2020 6:06 pm
I've been struggling to get my Feather M0 WiFi to stream to my Adafruit IO account. I've followed the example and in the "Adafruit IO Arduino" library using the first sketch "adafruitio_00_publish". But the serial output only shows "Connecting to Adafruit IO......" with continuing dots forever.
I altered the program by uncommenting #define USE_WINC1500. The program throws an error if it isn't uncommented. I think this is fine since the Feather M0 WiFi uses ATWINC1500.
Still it won't connect.
FYI, I can push to my IO account using python on the computer, and I can connect my Feather to the WiFi using the WiFi 101 script.
At this point, I'm beating my head against a wall.
jrwst36
Re: Can't connect Feather M0 WiFi to Adafruit IO
by Systembolaget on Tue Jun 02, 2020 7:58 am
Was discussed here viewtopic.php?f=56&t=164725#p811069 where Adafruit provided an update to make it to work.
Systembolaget
by brubell on Wed Jun 03, 2020 11:00 am
Did you update the WINC1500 firmware's SSL certificate storage to include Adafruit IO?
This page in the WINC1500 learn guide describes the process:
https://learn.adafruit.com/adafruit-fea ... rtificates
Please let me know if that did not work for you.
brubell
