Adafruit IO Publish example not compiling. Cannot declare va
by Robert_Beatty on Sun Jun 07, 2020 5:10 pm
I am getting an error when I attempt to compile the example "IO Publish" sketch provided in the Adafruit IO Arduino library:
cannot declare variable 'io' to be of abstract type 'AdafruitIO_Ethernet'
I am using a w5500 ethernet module not WIFI, so as per the instructions in the example, I uncommented the Ethernet-related lines in the config.h and took out the wifi-related lines. (I have also tried the examples with WIFI, but I get the same sort of "cannot declare variable' errors.)
Here is the main sketch code, the simplified config.h, and the full error text.
// Adafruit IO Publish Example
#include "config.h"
// this int will hold the current count for our sketch
int count = 0;
// set up the 'counter' feed
AdafruitIO_Feed *counter = io.feed("counter");
  // start the serial connection
  Serial.begin(115200);
  // wait for serial monitor to open
  while(! Serial);
  Serial.print("Connecting to Adafruit IO");
  // connect to io.adafruit.com
  io.connect();
  // wait for a connection
  while(io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
  // save count to the 'counter' feed on Adafruit IO
  Serial.print("sending -> ");
  Serial.println(count);
  counter->save(count);
  // increment the count by 1
  count++;
  // Adafruit IO is rate limited for publishing, so a delay is required in
  // between feed->save events. In this example, we will wait three seconds
  // (1000 milliseconds == 1 second) during each loop.
  delay(3000);
/************************ Adafruit IO Config *******************************/
#define IO_USERNAME    "Robert_Beatty"
#define IO_KEY         "600e39c9e725c55593bb9cfa9dcb48220df00efc"
#include "AdafruitIO_Ethernet.h"
AdafruitIO_Ethernet io(IO_USERNAME, IO_KEY);
FULL ERROR TEXT
Arduino: 1.8.12 (Mac OS X), Board: "Adafruit Grand Central M4 (SAMD51), Enabled, 120 MHz (standard), Small (-Os) (standard), 50 MHz (standard), Arduino, Off"
In file included from /Users/robertbeatty/Documents/Arduino/AIO_TEST/AIO_TEST.ino:3:0:
config.h:7:21: error: cannot declare variable 'io' to be of abstract type 'AdafruitIO_Ethernet'
In file included from sketch/config.h:6:0,
/Users/robertbeatty/Documents/Arduino/libraries/Adafruit_IO_Arduino/src/AdafruitIO_Ethernet.h:35:7: note: because the following virtual functions are pure within 'AdafruitIO_Ethernet':
class AdafruitIO_Ethernet : public AdafruitIO {
In file included from /Users/robertbeatty/Documents/Arduino/libraries/Adafruit_IO_Arduino/src/AdafruitIO_Ethernet.h:28:0,
from sketch/config.h:6,
/Users/robertbeatty/Documents/Arduino/libraries/Adafruit_IO_Arduino/src/AdafruitIO.h:136:16: note: virtual void AdafruitIO::_disconnect()
virtual void _disconnect() = 0;
exit status 1
Robert_Beatty
Re: Adafruit IO Publish example not compiling. Cannot declar
by brubell on Mon Jun 08, 2020 11:34 am
Hi Robert, I'm fixing this issue today and will update with a link when it's ready.
brubell
by Robert_Beatty on Mon Jun 08, 2020 11:39 am
Excellent. Thank you.
Robert_Beatty
by brubell on Mon Jun 08, 2020 12:34 pm
Ok, I just updated and bumped the library. You should be able to download the latest version of Adafruit IO Arduino which fixes this issue here:
https://github.com/adafruit/Adafruit_IO ... /tag/3.6.3
brubell
by Robert_Beatty on Mon Jun 08, 2020 12:42 pm
OK. Thank you. I'll try it now.
Robert_Beatty
by Robert_Beatty on Mon Jun 08, 2020 1:19 pm
Success!
I deleted the older library folder, dropped in the new one, re-started Arduino, and tried compiling the test program. It compiled with no errors. I also compiled my actual project sketch with no errors. So, I think you got it. Thank you.
I'll now move forward to the next step to see if I can get my sketch to feed data up to the IO platform.
Thanks for the help,
—Robert
Robert_Beatty
by brubell on Tue Jun 09, 2020 11:32 am
no problem - thanks for reporting the issue.
brubell
