BUG: dragging outside block create window closes it
by cjdshaw on Fri Jun 12, 2020 7:54 am
Several times, I've spent a while setting up a block, then had the "Create" window vanish, losing all my work. I've worked out that this seems to be when you drag the mouse from inside a field to outside the window. This is particularly annoying when using the colour picker, for example, which requires dragging, so a slight overshoot and everything vanishes
cjdshaw
Re: BUG: dragging outside block create window closes it
by brubell on Mon Jun 15, 2020 11:42 am
Good point, this modal is more involved than some of our other modals (feed settings/create feed). I've filed bug report to enforce closing this window by clicking the 'X' instead of outside of the modal.
brubell
