MQTT Library can't send floats without dtostrf.h
by jdamelio on Thu Jun 25, 2020 10:32 pm
I am getting some peculiar behavior from the Adafruit MQTT library. Publishing floats, using the "publish" function, causes the error: "MQTT ERROR: error saving data on jdamelio/feeds/test-feed, data missing required value" to appear on the Adafruit IO webpage. Other data types work fine.
If I both add #include "avr/dtostrf.h" and use the dtostrf function in the body of my sketch, the publishes work.
What is going on here? It seems like without the include, the mqtt library doesn't have a dtostrf function to use, but I don't understand how it could compile if this were the case.
I'm using a Metro M4 Airlift Lite with Arduino.
jdamelio
Re: MQTT Library can't send floats without dtostrf.h
by brubell on Fri Jun 26, 2020 9:58 am
dtostrf isn't included with the SAMD architecture, you may want to include it here: https://github.com/adafruit/Adafruit_MQ ... MQTT.h#L27 instead of the sketch itself.
Alternatively, the Adafruit IO Arduino library handles type conversions for sending to Adafruit IO, for you: https://github.com/adafruit/Adafruit_IO_Arduino
brubell
