After multiple failed attempts to even get them to talk, I finally can send "something" to Adafruit IO from my M5StickC. I set up a feed on IO, and am trying to use M5FLOW to code the stickC, so that I can then help students do the same. But I am getting and error on IO. "MQTT ERROR: mrwomack 63.248.53.105 PUBLISH to topic ` mrwomack/feeds/m5-data.m5-temp` rejected, failed to authorize publish"
What do I need to change to fix this, or what additional info is needed so that I can get help? Thank you in advance.
Errors between M5StickC & Adafruit IO
- mrwomack
Re: Errors between M5StickC & Adafruit IO
I found the issue. When I copied the key, it added a space before the 'mrwomack' in the key.
