8 Channel LoRaWAN gateway compatibility with LoRa modules.
by nishi2097 on Mon Jun 29, 2020 9:59 pm
Hi, I am working with the 8 channel LoRaWAN gateway(8 Channel LoRa Gateway Kit comes with Raspberry Pi, LoRa and GPS
PRODUCT ID: 4327 ) and wanted to get the application running using a HopeRFM96 LoRa Radio module. I have been able to register the gateway to my things network cloud but at the same time I am not able to get my application running through the LoRa module RFM96. while trying to send data to the gateway the transmitter gets stuck at Payload sending. I have been using Radiohead library with teensy3.6 micro-controller. I would like to know which LoRa module will be able to be compatible with teensy 3.6 and the 8 channel gateway so that I could send the data to the gateway. Thanks in advance. Would like to hear the suggestions soon.
nishi2097
Re: 8 Channel LoRaWAN gateway compatibility with LoRa module
by brubell on Fri Jul 03, 2020 10:45 am
Which LoRa radio module product are you using?
brubell
by nishi2097 on Tue Jul 07, 2020 1:00 am
I am using LoRa RF96 radio
nishi2097
by brubell on Tue Jul 07, 2020 10:10 am
ok - which library are you using to send data to the gateway? are your gateway and the node on the same channel?
brubell
by nishi2097 on Tue Jul 07, 2020 3:41 pm
I am using Radiohead with teensy 3.6 being the controller and yeah both my gateway and LoRa are configured for 915MHz since I am operating from USA
nishi2097
