aio.receive method creates 404 not found error
by hwdornbush on Thu Jul 09, 2020 5:59 pm
I have created two python programs that successfully send temperature and humidity data to Adafruit IO
I created a new feed named digital, a new dashboard named digital, and a new block to toggle the LED on and off.
I tried the example program digital_out.py from https://learn.adafruit.com/adafruit-io- ... ython-code
I added my ADAFRUIT_IO_KEY and ADAFRUIT_IO_USERNAME
I made no other changes to this example code.
When I run it, I get:
File "/home/pi/Documents/digital_out.py", line 45, in <module>
data = aio.receive(digital.key)
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 216, in receive
return Data.from_dict(self._get(path))
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 118, in _get
self._handle_error(response)
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 108, in _handle_error
raise RequestError(response)
Adafruit_IO.errors.RequestError: Adafruit IO request failed: 404 Not Found - not found - API documentation can be found at https://io.adafruit.com/api/docs
I tried reloading adafruit-io:
$ pip3 install adafruit-io
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: adafruit-io in ./.local/lib/python3.7/site-packages (2.4.0)
Requirement already satisfied: paho-mqtt in ./.local/lib/python3.7/site-packages (from adafruit-io) (1.5.0)
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (from adafruit-io) (2.21.0)
I looked through bug reports and saw two similar reports which requested
aio = Client(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
feeds = aio.feeds()
print(feeds)
be added to the script, so I did this. As a result, I get
[Feed(name='Welcome Feed', key='welcome-feed', description=None, unit_type=None, unit_symbol=None, history=True, visibility='private', license=None, status_notify=False, status_timeout=4320), Feed(name='temperature', key='temperature', description='temperature and humidity feed from Pi DHT22', unit_type=None, unit_symbol=None, history=True, visibility='private', license=None, status_notify=False, status_timeout=4320), Feed(name='humidity', key='humidity', description='', unit_type=None, unit_symbol=None, history=True, visibility='private', license=None, status_notify=False, status_timeout=4320), Feed(name='digital', key='digital', description=None, unit_type=None, unit_symbol=None, history=True, visibility='private', license=None, status_notify=False, status_timeout=4320)]
How do I get this example code to run successfully?
hwdornbush
Re: aio.receive method creates 404 not found error
by brubell on Fri Jul 10, 2020 10:02 am
I'm unable to replicate the 404 error:
# import Adafruit IO REST client.
from Adafruit_IO import Client, Feed, RequestError
# Create an instance of the REST client.
try: # if we have a 'digital' feed
    digital = aio.feeds('digital')
except RequestError: # create a digital feed
    feed = Feed(name="digital")
    digital = aio.create_feed(feed)
print(data)
outputs expected:
Data(created_epoch=None, created_at='2020-07-10T13:52:52Z', updated_at='2020-07-10T13:52:52Z', value='1', completed_at=None, feed_id=1157950, expiration='1599573172.0', position=None, id='0EG0X017NKRDS5527E3YXN0VP4', lat=None, lon=None, ele=None)
Could you try running this code and letting me know if it also 404s?
brubell
by brubell on Fri Jul 10, 2020 10:37 am
Edit - I was able to reproduce this with by making a new digital feed. The call to `receive` in Python calls our API's `digital/last.json` which throws a 404 no data exists (which is True on the first run). A quick workaround would be to write a 0 value to the feed by calling aio.send(digital.key, '0') before entering the while True loop.
I filed an issue over on the repository so we can better handle this exception without needing a workaround.
brubell
by hwdornbush on Fri Jul 10, 2020 12:41 pm
Yes, I inserted your suggested code of
which got the code to go by the initial 404 error. However, the default choice of blocks includes one that provides ON or OFF, not 1 or 0. As a result, the example code fails when it receives ON rather than 1 from AIO.
I changed your suggested code to
aio.send(digital.key, 'OFF')
I now get the print output that the "received" value is either ON or OFF but the LED does not respond.
I changed the code for controlling the LED to
if data.value == 'ON':
led.value = True
else:
led.value = False
This works. I changed the block so that its values are 1 or 0 rather than On or Off, and now the original code works.
hwdornbush
