Using a pushbutton to toggle a dashboard switch?
by BeauJayce on Mon Jul 13, 2020 5:28 am
I'm building a IO-controlled xmas tree light switch, and have run into a problem. My criteria are:
1) Toggle switch on dashboard (powerswitch feed) to tell ESP to turn a relay on or off <done>
2) Light on the dashboard (powerlight feed); value set from the ESP after the relay is switched, to show message success <done>
3) Physical momentary button to manually toggle the IO powerswitch <record scratch>
The issue I'm trying to solve with #3 is this; I turn off the lights with the IO toggle. Wife gets up in the morning and wants to turn them back on, which would be a lot easier with a physical button. So far I've gotten halfway there. :)
I'm using powerlight as a value, and want to set the powerswitch to the opposite of powerlight (toggle it on or off based on the current state). I've tried using powerswitch as a the source state, but was getting some double-replies from IO. Also tried reading the RELAY_PIN value and using that as the source. Any value would be fine, whatever I can use to say "set powerswitch to not-that."
So, if the dashboard powerlight is On, pressing the button WILL turn off powerswitch.
Serial shows:
23:26:24.600 -> Button pressed
23:26:24.847 -> IO switch is OFF
If the dashboard powerlight is Off, pressing the button will NOT turn on powerswitch.
Serial shows:
23:26:00.903 -> Button pressed
23:26:01.081 -> IO switch is OFF
CODE: SELECT ALL | TOGGLE FULL SIZE
#include "config.h"
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#define LED_PIN 2
#define RELAY_PIN 4
#define BUTTON_PIN 14
const char* ssid = "SSID";
const char* password = "PASS";
AdafruitIO_Feed *powerswitch = io.feed("powerswitch");
AdafruitIO_Feed *powerlight = io.feed("powerlight");
int button;
pinMode(LED_PIN, OUTPUT);
pinMode(RELAY_PIN, OUTPUT);
pinMode(BUTTON_PIN, INPUT);
digitalWrite(LED_PIN, HIGH);
digitalWrite(RELAY_PIN, LOW);
Serial.begin(115200);
WiFi.begin(ssid, password);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
delay(3000);
ESP.restart();
ArduinoOTA.setHostname("TreeESP");
ArduinoOTA.begin();
Serial.print("Connecting to Adafruit IO");
io.connect();
powerswitch->onMessage(handleMessage);
while(io.status() < AIO_CONNECTED) {
Serial.print(".");
delay(1000);
Serial.println();
Serial.println(io.statusText());
powerswitch->get();
io.run();
ArduinoOTA.handle();
button = digitalRead(BUTTON_PIN);
if (button == LOW) {
Serial.println("Button pressed");
powerlight->get();
powerswitch->save(!powerlight);
void handleMessage(AdafruitIO_Data *data) {
if(data->toPinLevel() == HIGH) {
Serial.println("IO switch is ON");
digitalWrite(RELAY_PIN, HIGH);
else {
Serial.println("IO switch is OFF");
digitalWrite(LED_PIN, !data->toPinLevel());
powerlight->save(data->toPinLevel());
BeauJayce
Re: Using a pushbutton to toggle a dashboard switch?
by BeauJayce on Tue Jul 14, 2020 2:59 am
BeauJayce wrote:I'm building a IO-controlled xmas tree light switch, and have run into a problem. My criteria are:
Serial shows:
Serial shows:
#include "config.h"
#define LED_PIN 2
#define RELAY_PIN 4
int button;
delay(3000);
ESP.restart();
ArduinoOTA.begin();
io.connect();
Serial.print(".");
delay(1000);
Serial.println();
powerswitch->get();
io.run();
powerlight->get();
else {
digitalWrite(RELAY_PIN, LOW);192.168.0.1 192.168.l.l
Before the nether update, I used to be able to sleep underwater. I have a completely underwater base that I live in thanks to the conduit, but now I can't spawn in it if I die. Is this intentional? Attempting to activate a bed tells me that it is obstructed and it only works when the bed is only one level deep in water.
BeauJayce
