PlatformIO woes with AdafruitIO
by electricphred on Mon Jul 13, 2020 1:09 pm
Hello:
Am having a terrible time trying to get AdafruitIO going under PlatformIO. Problems see to stem for wrong libraries and irrelevant libraries automagically downloaded as part of the AdafruitIO packagage? Have had to disable both the Sleepy Dog Library and WiFi101 which both throw errors. Have read on these forums that WiFi101 isn't even compatible with my ESP32 (Thing Plus).
could use help on my latest multiple errors stemming from WiFiclient which are preventing a compile:
WiFiClientSocketHandle()
close(sockfd);
Where identifier 'close' is undefined. WiFiclient seems to depend on WiFi and I'm not certain that I've got an ESP32 variant.
here's another thread on these excessive library installs: viewtopic.php?f=56&t=167263
and this one on Sleepy Dog: viewtopic.php?f=56&t=167271
electricphred
Re: PlatformIO woes with AdafruitIO
by electricphred on Mon Jul 13, 2020 8:50 pm
OK my builds of the AdafruitIO examples now seems busted under Arduino IDE where I had it working last week. Don't know/think this is related to the update of that library to 3.7 which i have done.
In the Arduino IDE my compile craps out after:
Using library WiFi at version 1.0 in folder: /Users/xxx/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/WiFi
under the more verbose compiler logs in PlatformIO I am also having trouble with a dependency of that library where 'close' is not defined in WebSocket handling
electricphred
by brubell on Wed Jul 15, 2020 11:57 am
Which board support package version do you have installed for the ESP32? Which ESP32 board are you using (vendor)?
brubell
by electricphred on Wed Jul 15, 2020 3:00 pm
I’ve been using platform “espressif32” and have variously used an Adafruit Feather Huzzah32 and a SparkFun ThingPlus Wroom32. Thanks.
electricphred
by electricphred on Thu Jul 16, 2020 2:46 pm
Tried uninstalling and reinstalling Arduino 1.8.13 and fresh libraries. How can I solve my WiFi.h problems preventing a compile of the Adafruit IO examples which I had running before?
Here's the output:
Multiple libraries were found for "WiFi.h"
Used: /Users/xxx/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/WiFi
Not used: /private/var/folders/9l/bmv1h9bx6mlb8lv_1x500nm00000gn/T/AppTranslocation/C70B2388-92FF-4EF0-A35B-B9E8CF2A4D0E/d/Arduino 7.app/Contents/Java/libraries/WiFi
Using library ESP32 at version 1.0 in folder: /Users/xxx/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/ESP32
Using library Adafruit_IO_Arduino-master at version 3.7.0 in folder: /Users/ccc/Documents/Arduino/libraries/Adafruit_IO_Arduino-master
Using library Adafruit_MQTT_Library at version 1.3.0 in folder: /Users/xxx/Documents/Arduino/libraries/Adafruit_MQTT_Library
Using library ArduinoHttpClient at version 0.4.0 in folder: /Users/fredwhitridge/Documents/Arduino/libraries/ArduinoHttpClient
Using library WiFiClientSecure at version 1.0 in folder: /Users/xxx/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/WiFiClientSecure
exit status 1
'WiFiClientSecure' does not name a type
I seem to be stuck in a similar place under PlatformIO where the problem seems to be around closing a socket, don't have that error at hand.
electricphred
by electricphred on Thu Jul 16, 2020 6:03 pm
Compile problem solved. Deleted Arduino IDE. Flushed libraries.
Exited IDE, Fired it up with the last known Adafruit IO working software and it least compiles.
Now to track down "Connection Failed!" a Scanner shows my Thing Plus Wroom32 has and IP address so more sleuthing...
electricphred
