esp32 feather output as NC with set delay and return to NO
by hutchproraider1 on Mon Jul 13, 2020 11:31 pm
Good afternoon,
i just got a esp32 huzzah Feather and I know pin 12 is used as output only ,
my question is can pin 12 or which other pin be used as an output to simulate a Normaly open to Normaly closed and with a delay 1 second to be able to connect via web to trigger a circuit by being normally open until I click on code similar to on or off lamp but with my computer on the 192.168.4.1 to make it normally closed for 1 second before it goes back Automatically to Normaly open with out clicking anything else ,
so what I'm trying to do is click once via web to make a (Normally open) to change to (normally closed) for 1 second and then make go back to Normally open automatically within a set time 1 second , so every time I click via web it goes from NO to NC for 1 second and back NO which activates another circuit.
Thanks a lot ,any help is greatly appreciated
hutchproraider1
Re: esp32 feather output as NC with set delay and return t
by brubell on Wed Jul 15, 2020 11:56 am
You may want to try a different GPIO pin which isn't output only like pin 14 or pin 15
brubell
by hutchproraider1 on Wed Jul 15, 2020 10:33 pm
Thank you , Brubell for the quick response
Do you know if there is link I can go to see other similar projects with the esp32 ? so I can take a look at the code
using pin 14 or 15 using web configuring No to NC and back to NO
Kind regards.
hutchproraider1
by brubell on Fri Jul 17, 2020 9:55 am
Not that I know of off-hand, sorry
brubell
