Nothing is working after the update to 3.7.0
Re: Nothing is working after the update to 3.7.0
by mandreko on Fri Jul 17, 2020 11:29 am
Indeed, that is a good test. I was doing similar things to no avail.
I used Brent's example code, and this is the serial output that I get:
Adafruit IO MQTTS (SSL/TLS) Example
Connecting to IoT
WiFi connected
IP address:
172.16.69.118
Connecting to MQTT... Connection failed
Retrying MQTT connection in 5 seconds...
Connection failed
Connection failed
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Soft WDT reset
>>>stack>>>
ctx: cont
sp: 3ffffde0 end: 3fffffc0 offset: 01a0
3fffff80: 00000001 3ffee5e8 3ffee7e8 40201192
3fffff90: 3fffdad0 00000000 3ffee830 402011e0
3fffffa0: 3fffdad0 00000000 3ffee830 40206014
3fffffb0: feefeffe feefeffe 3ffe84e4 40100b85
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x4010f000, len 3664, room 16
tail 0
chksum 0xee
csum 0xee
v39c79d9b
~ld
After that, it just repeats.
mandreko
by john87 on Fri Jul 17, 2020 11:41 am
I had boot mode 3,6 and 3,7 errors getting TI117 and BME 280s working. In one case that was a wrong pin assignment for a Due. I'm going to double-check that I have the right board selected.
john87
by mandreko on Fri Jul 17, 2020 12:25 pm
More interesting data:
For funsies, I changed Brent's example script to connect to my tethered phone, to get a different IP. It connected, and fed data into the IO Monitor.
I thought maybe my IP had been blocked, since I saw some news about that. However, on the same network, I used an example AdafruitIO Python script (https://github.com/adafruit/Adafruit_IO ... _pubsub.py) and it published to my feeds just fine.
I'm scratching my head over here...
mandreko
by proecogreen on Fri Jul 17, 2020 2:09 pm
Everything seems to work now!! Thanks!!
proecogreen
by john87 on Sat Jul 18, 2020 10:03 am
@proecogreen: did it just start working, or did you do something?
I tried the test program with interesting results. Basically, it does not work on a Feather Huzzah or a NodeMCU. Both connect to my WiFi and get IP addresses just fine.
However, in one case on the NodeMCU, after about an hour, it started publishing. I restarted it, and it failed as before and it was still failing after 8 hours.
Assuming I/we get things running correctly again, what is the plan to prevent a repeat in two years when the current certificate expires? Is there a way to do it with zero interruption?
john87
by proecogreen on Sat Jul 18, 2020 1:25 pm
@John87: I also updated the Arduino IDE along with Adafriut IO, Adafruit MQTT and ArduinoHTTP libraries to the Latest version!
proecogreen
by mandreko on Sun Jul 19, 2020 10:01 am
I'm still trying to figure out why my ESP8266 can't run the test script, but my computer can publish to IO. Changing only the WiFi AP in my ESP8266 ino file lets me publish again, which makes no sense.
mandreko
by john87 on Sun Jul 19, 2020 9:45 pm
@proecogreen, I have tried a new computer programing a NodeMCU with a fresh ide 1.8.13, the new library and whatever it needs, and an older setup (1.8.12) with updated library. This one is programing a Feather Huzzah.
In the most simple terms, neither works. Both will usually connect after failing for 15 minutes to 2 hours but sometimes are still failing after 8 hours.
Before the upgraded library, connecting to Adafruit was always the least of my problems.
john87
by mandreko on Mon Jul 20, 2020 4:11 pm
Brent,
Is it possible that specific hosts could be banned from IO or anything? I have no outbound firewall rules on my network, and with Wireshark, I see the ESP8266 connecting to io.adafruit.com, but it doesn't succeed.
As another test, I setup a mini-travel router behind my main router, but had it use a VPN client, and my ESP8266 chip returns data to IO. I can't seem to figure out why it won't do it from my home network.
mandreko
by brubell on Tue Jul 21, 2020 11:04 am
I just set up an ESP8266, updated the BSP and libraries, and was able to connect to Adafruit IO and pub/sub data. I'm going to leave this running as a soak test to see if anything abnormal pops up.
brubell
by brubell on Tue Jul 21, 2020 11:10 am
john87 wrote:@proecogreen, I have tried a new computer programing a NodeMCU with a fresh ide 1.8.13, the new library and whatever it needs, and an older setup (1.8.12) with updated library. This one is programing a Feather Huzzah.
Are you able to connect using MQTT (not secure MQTTS)?
Could you try running this sketch? https://github.com/adafruit/Adafruit_MQ ... sp8266.ino
brubell
by mandreko on Tue Jul 21, 2020 11:39 am
brubell wrote:I just set up an ESP8266, updated the BSP and libraries, and was able to connect to Adafruit IO and pub/sub data. I'm going to leave this running as a soak test to see if anything abnormal pops up.
Mine works too, on any wifi except my own :(
mandreko
by john87 on Tue Jul 21, 2020 12:07 pm
I'll have to try the non-secure version later. What is BSP?
John
john87
by john87 on Tue Jul 21, 2020 9:17 pm
I tried the new example and it's the same: WDT resets, connects to WiFi quickly, may or may not connect to the server.
john87
by brubell on Wed Jul 22, 2020 10:55 am
john87 wrote:I'll have to try the non-secure version later. What is BSP?
John
BSP is board support package. If you navigate to Tools->Board Manager, and type ESP8266, you should be able to view the current board support package version.
Ok, this type of exception with the ESP are difficult for me to debug from my end. I'll need some assistance from you since I can not reproduce this bug.
Can you install the EspExceptionDecoder plugin:
https://github.com/me-no-dev/EspExcepti ... stallation
When you get the WDT reset and stack dump exception, open tools->esp exception decoder, and paste the stack trace into the windows pane. (https://github.com/me-no-dev/EspExceptionDecoder#usage)
Then, copy and paste the results from the bottom pane into this thread so I can analyze the issue better.
brubell
