ESP32/ESP8266 in university network
by mandina_choilab on Fri Jul 17, 2020 9:10 am
I had 2 temp/humidity sensors that sent data to adafruit using MQTT at home. You can check the repository here https://github.com/matiasandina/temp_sensor
I thought it was as simple as connect to the new internet in the campus and all set. But NO. It seems my university has a list of "allowed ports" (1883 not being one of them). Is there a way I configure the MQTT port so that I can connect to Adafruit using the "allowed ports" in my university?
What are other alternatives?
mandina_choilab
Re: ESP32/ESP8266 in university network
by brubell on Fri Jul 17, 2020 9:58 am
You may want to ask this question on the MicroPython forums: https://forum.micropython.org/
brubell
by mandina_choilab on Fri Jul 17, 2020 10:19 am
I am not sure the problem is on the micropython side, since I had it working with MQTT and Adafruit IO at home. The problem that I have is that my University is blocking the ports Adafruit is expecting, so I figured there might be a way to configure things in Adafruit (and later change the port in the python script from 1833 to whatever).
If I have no luck here, I will try in micropython forum.
mandina_choilab
by brubell on Mon Jul 20, 2020 10:17 am
mandina_choilab wrote:Hi,
You can't change the port Adafruit IO's MQTT broker uses, it's either 1883 (insecure) or 8883 (secure) and set on the server-side.
brubell
