Issues with ABC = new Adafruit_MQTT_Subscribe(mqtt, MQTT_FEE
by behmadi on Wed Jul 22, 2020 11:45 pm
OP1= new Adafruit_MQTT_Subscribe(mqtt, MQTT_FEED1);
I have been trying to construct MQTT_FEED to include account name and feed
account name is uploaded from WiFiconfig in to string(0).
  WiFiClient client;
  Adafruit_MQTT_Client *mqtt;
  Adafruit_MQTT_Subscribe *OP1;
void setup () {
  char *strings[2];
  string[0] = "behmadi"
  const char* MQTT_NAME  = strings[0];
  const char* feed1 =  "/feeds/op1";
  char MQTT_NAME_FEED1[20] = "\0";
  strcat(MQTT_NAME_FEED1,MQTT_NAME);
  strcat(MQTT_NAME_FEED1,feed1);
  delay(200);
  String s1((const __FlashStringHelper*) MQTT_NAME_FEED1);
  const char* MQTT_FEED1 = s1.c_str();
   Serial.println(MQTT_FEED1); //"prints -- behmadi/feeds/op1 ---- in serial monitor
   mqtt = new Adafruit_MQTT_Client(&client, MQTT_SERV, MQTT_PORT, MQTT_NAME, MQTT_PASS);
   OP1 = new Adafruit_MQTT_Subscribe(mqtt, MQTT_NAME_FEED1);
   mqtt->subscribe(OP1);
I have tried many ways combining the two, all attempt resulted the combined "behmadi/feeds/op1" in my serial print.
My IO dashboard displays
"MQTT ERROR: rejected, not a valid topic format"
or
"MQTT ERROR: aedes_FNQbOxBN9C9T 60.240.148.110 PUBLISH to topic `` rejected, topic is not a recognized format"
if I change " const char* MQTT_FEED1 = s1.c_str(); " line in above code to "const char* MQTT_FEED1 = "behmadi/feeds/op1;"
it works perfectly
if I use "OP1= new Adafruit_MQTT_Subscribe(mqtt, MQTT_NAME "/feeds/op1"); it results in compile error "expected ')' before string constant"
anyone knows how to construct this to include username and feed
Many thanks
behmadi
Re: Issues with ABC = new Adafruit_MQTT_Subscribe(mqtt, MQTT
by behmadi on Sun Jul 26, 2020 9:12 am
All sorted
Code was a mess, pointers and buffers were all a big shamble
Adafriut_MQTT_Subscribe works perfectly
behmadi
