IO Output 'handleMessage' problem
Re: IO Output 'handleMessage' problem
once I have uploaded the sketch to the ESP8266, it connects fine, it will receive the current state of the switch on the dashboard. But when I change the state of the switch, nothing happens, there is no change in the serial monitor. But if I reset the ESP8266, it will then receive the changed state once it has reconnected to Adafruit IO.
Buddyboy75 wrote:Yes it connects with adafruit IO fine, the serial monitor shows me what state the dashboard is in ie. "High" or "Low".
But when I click the button on the IO dashboard, nothing happens with the 8266, also no change on the serial monitor. But if I press the reset on my relay, the 8266 then receives the change state from adafruit IO.
For some reason, its not continuously refreshing, so will not recieve a change of state from adafruit IO, not with out pressing reset on my relay.,
When it receives "val 1" the slider changes over to on (1) when it receives any other value (0,2,3 etc.) the slider changes to off (0).
Can I use MQTT to operate the relays?
Adafruit MQTT Library ESP8266 Example
Must use ESP8266 Arduino from:
https://github.com/esp8266/Arduino
Works great with Adafruit's Huzzah ESP board & Feather
----> https://www.adafruit.com/product/2471
----> https://www.adafruit.com/products/2821
products from Adafruit!
Written by Tony DiCola for Adafruit Industries.
MIT license, all text above must be included in any redistribution
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
// the on off button feed turns this LED on/off
#define RELAY1 0
/************************* WiFi Access Point *********************************/
#define WLAN_SSID "My SSID"
#define WLAN_PASS "My Password"
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER "io.adafruit.com"
#define AIO_SERVERPORT 1883 // use 8883 for SSL
#define AIO_USERNAME "My Username"
#define AIO_KEY "My Key"
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
// or... use WiFiFlientSecure for SSL
//WiFiClientSecure client;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_USERNAME, AIO_KEY);
/****************************** Feeds ***************************************/
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
Adafruit_MQTT_Subscribe loungelight = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/loungelight");
/*************************** Sketch Code ************************************/
// Bug workaround for Arduino 1.6.6, it seems to need a function declaration
// for some reason (only affects ESP8266, likely an arduino-builder bug).
void MQTT_connect();
pinMode(RELAY1, OUTPUT);
Serial.begin(115200);
delay(10);
Serial.println(F("Adafruit MQTT demo"));
// Connect to WiFi access point.
Serial.println(); Serial.println();
Serial.print("Connecting to ");
Serial.println(WLAN_SSID);
WiFi.begin(WLAN_SSID, WLAN_PASS);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println();
Serial.println("WiFi connected");
Serial.println("IP address: "); Serial.println(WiFi.localIP());
// Setup MQTT subscription for onoff & slider feed.
mqtt.subscribe(&loungelight);
uint32_t x=0;
// Ensure the connection to the MQTT server is alive (this will make the first
// connection and automatically reconnect when disconnected). See the MQTT_connect
// function definition further below.
MQTT_connect();
// this is our 'wait for incoming subscription packets' busy subloop
// try to spend your time here
Adafruit_MQTT_Subscribe *subscription;
while ((subscription = mqtt.readSubscription(5000))) {
// Check if its the onoff button feed
if (subscription == &loungelight) {
Serial.print(F("Lounge Lights: "));
Serial.println((char *)loungelight.lastread);
if (strcmp((char *)loungelight.lastread, "1") == 0) {
digitalWrite(RELAY1, 1);
if (strcmp((char *)loungelight.lastread, "0") == 0) {
digitalWrite(RELAY1, 0);
// ping the server to keep the mqtt connection alive
if(! mqtt.ping())
mqtt.disconnect();
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
int8_t ret;
// Stop if already connected.
if (mqtt.connected()) {
return;
Serial.print("Connecting to MQTT... ");
uint8_t retries = 3;
while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
Serial.println(mqtt.connectErrorString(ret));
Serial.println("Retrying MQTT connection in 5 seconds...");
mqtt.disconnect();
delay(5000); // wait 5 seconds
retries--;
if (retries == 0) {
// basically die and wait for WDT to reset me
while (1);
Serial.println("MQTT Connected!");
