Hello Adafruit,
I have an Arduino Uno Wifi Rev.2 and I am trying to use your MQTT Library for posting data to Adafruit IO. Library version is 1.3.0.
Problems I have when I try to compile:
Arduino:1.8.13 (Windows 10), Tarjeta:"Arduino Uno WiFi Rev2, None (ATMEGA4809)"
In file included from C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.h:25:0,
from C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp:22:
C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp: In member function 'const arduino::__FlashStringHelper* Adafruit_MQTT::connectErrorString(int8_t)':
C:\Users\xxx\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.6\cores\arduino/Arduino.h:30:20: error: cannot convert 'const char*' to 'const arduino::__FlashStringHelper*' in return
#define F(str) (str)
C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp:278:12: note: in expansion of macro 'F'
return F(
C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp:281:12: note: in expansion of macro 'F'
return F(
C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp:284:12: note: in expansion of macro 'F'
return F("The MQTT service is unavailable");
C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp:286:12: note: in expansion of macro 'F'
return F("The data in the user name or password is malformed");
C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp:288:12: note: in expansion of macro 'F'
return F("Not authorized to connect");
C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp:290:12: note: in expansion of macro 'F'
return F("Exceeded reconnect rate limit. Please try again later.");
C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp:292:12: note: in expansion of macro 'F'
return F("You have been banned from connecting. Please contact the MQTT "
C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp:295:12: note: in expansion of macro 'F'
return F("Connection failed");
C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp:297:12: note: in expansion of macro 'F'
return F("Failed to subscribe");
C:\Users\xxx\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp:299:12: note: in expansion of macro 'F'
return F("Unknown error");
exit status 1
Error compilando para la tarjeta Arduino Uno WiFi Rev2.
