FreeRTOS or Scheduler and Adafruit IO
by dylancw on Thu Jul 30, 2020 1:25 am
Has anyone here had luck using the Adafruit IO library with FreeRTOS, Scheduler, or another task management library? I am trying to debug as usual using the USB serial port and whenever there's a task problem it's very hard to see because the USB serial connection dies first...
I was timing the update time for the io.run() function and it's taking 314 milliseconds on average here, which is far too long to wait for without pre-empting if you want to control or regulate anything. (Network is relatively fast, SAMD21 based arduino with W5500 wired ethernet to a tp-link switch to a Google Nest router to cable wifi, home cable wifi is 290Mbps download, 20Mbps upload. Ping latency to adafruit server is 16ms).
Let me know your thoughts, thanks!
dylancw
Re: FreeRTOS or Scheduler and Adafruit IO
by brubell on Fri Jul 31, 2020 9:51 am
I haven't tried FreeRTOS/Scheduler with Adafruit IO Arduino.
If you're using FreeRTOS, you may want try using the FreeRTOS IoT Library for MQTT: https://www.freertos.org/mqtt/index.html
or the Adafruit MQTT Library https://github.com/adafruit/Adafruit_MQTT_Library
The Adafruit IO MQTT broker documentation can be found on https://io.adafruit.com/api/docs/mqtt.h ... o-mqtt-api
brubell
