I've been trying to get a project working for months using the IO Home Security learning project as my foundation. My project also uses the learning project for a solar powered setup for my Feather HUZZAH since I do not have a power supply where this will be used (but it's in range of WiFi). The IO Home Security project example jumps over to the Raspberry Pi Zero W and Python programs for snapping pictures which I learned the hard way is a huge drain on battery power even when the Pi is turned off. I learned a bit, but in the end this was a wasted investment for my project since the solar panels can't produce enough juice to keep the Pi powered. So I persisted and bought the Mini TTL Serial JPEG Camera (VC0706) for use with my Feather HUZZAH. With some trial and error I have been able to get the Arduino program to successfully snap pictures and move the JPEG from the Camera to the HUZZAH. I even got it working to convert the image to Base 64 using help from another project I found on Github. I know it's working because if I copy & paste the converted string to my IO picture object and manually Add the Data, the picture appears. What I can't get working is the feed-->save() function using the MQTT client. I get a Stack overflow even when using the smallest image size possible (160x120). Does Adafruit have any examples of how to upload a picture to IO for a Feather HUZZAH?
