Sharing data using minimqtt on_meessage callback
by tellingmachine on Tue Aug 04, 2020 12:02 pm
I am having trouble with sharing data between minimqtt on_message callback with the main loop. I am using a Metro M4 Airlift with CircuitPython 6.0.2 (the drop from 8/3/2020).
Here is my on_message function call back definition:
def message(client, topic, message):
    # This method is called when a topic the client is subscribed to
    print("Converting from Json to Object")
    testrig_received_value_dict=json.loads(message) #decode json data
    print(type(testrig_received_value_dict))
    print("fanload = ",testrig_received_value_dict["fanload"])
    print("New message on topic {0}: {1}".format(topic, message))
    fanload = testrig_received_value_dict["fanload"]
    print(fanload)
    fanpwm.duty_cycle = fanload
fanpwd is defined previously as:
fanpwm = pulseio.PWMOut(board.D12, duty_cycle=0x7fff, frequency=25000)
My challenge is that whatever I try I can't get data exchanged between the callback function and the rest of the program in code.py.
I tried using a dictionary that is declared in the body of code.py. This did not work. I read that it should be defined in the main function. Where can I find the main function in CircuitPython. Can you please provide an example or point me to some documentation that can explain what I need to do to pass data between the on_message callback the io of my board?
All of the examples that I found on the internet do print(message), but It would be helpful to provide examples that take the incoming message and use it to set e.g. the duty_cycle of a pwm output.
Thanks for your help.
Btw CircuitPython is pretty awesome.
tellingmachine
Re: Sharing data using minimqtt on_meessage callback
by tellingmachine on Tue Aug 04, 2020 12:23 pm
I did some more reading. It seems like not the Cortex M4 but the ESP32 co-processor is handing the incoming mqtt messages. The issue might not just be a CircuityPython syntax question, but looking at the data transfer between the ESP32 and the Cortex M4.
tellingmachine
by brubell on Wed Aug 05, 2020 11:23 am
Using callbacks is tricky. Without knowing what the rest of your code.py looks like, I'll explain the process in general terms:
After the MiniMQTT client has been defined, prior to establish a connection, you need to provide MiniMQTT's on_message method handler with the name of the callback method.
Reference: https://github.com/adafruit/Adafruit_Ci ... ing.py#L94
Within the "main loop" (while True), each call of mqtt_client.loop() will check for incoming packets. If the packet is a publish packet, the method you attached to on_message will be executed.
You may need to make the fanpwm variable a global variable.
In Python, variables that are only referenced inside a function are implicitly global. If a variable is assigned a value anywhere within the function’s body, it’s assumed to be a local unless explicitly declared as global.
- https://docs.python.org/3/faq/programmi ... -in-python
brubell
by tellingmachine on Thu Aug 06, 2020 5:36 pm
Thanks for your feedback. I got it working by declaring the dictionary variable with global in the on_message callback function.
    global testrig_received_value_dict
Here is the updated function that passes the received value back to the main loop.
    print(fanload)
tellingmachine
