How to use data/previous, data/next ?
by yennifs on Tue Aug 11, 2020 3:53 pm
Hi;
I am confused about using these endpoints and I don't understand how the could possibly work without knowing a starting point. Do I need to pass a current ID so that the one before or after it can be returned?
I get results from:
data/retain
data/first
data/last
but I get 404 errors from
data/next
data/previous
Any advice?
yennifs
Re: How to use data/previous, data/next ?
by brubell on Fri Aug 14, 2020 9:47 am
data/next
data/previous
data/previous is not a valid endpoint, data/last is the endpoint (https://io.adafruit.com/api/docs/#get-last-data)
As for data/next returning a 404, could you please post the code you're using to make the HTTP request?
brubell
cron
