Adafruit IO is Helping Tucson, Arizona Evaluate Strategies f
by biod101 on Sat Aug 15, 2020 5:57 pm
Per request for a blog entry (https://forums.adafruit.com/viewtopic.php?f=56&t=167401), here is one for your consideration.
Adafruit IO is Helping Tucson, Arizona Evaluate Strategies for Climate Change Resiliency
The desert Southwest is experiencing record-high temperatures coupled with severe drought. In prior years, the monsoon season (mid-June through September) provided relief through daily afternoon thunderstorms, but the trend these days is one of brief, intense storms followed by weeks of dry weather. This trend is increasing demand for supplemental water resources in Arizona, which are pumped uphill from distant reservoirs like Lake Havasu requiring fossil fuels. Hans Huth is a hydrologist with the Arizona Department of Environmental Quality (ADEQ). Hans was interested in understanding how applying mulch to desert landscapes might reduce demand for irrigation, so he set up an experiment in his backyard using a Feather Huzzah ESP8266 coupled with air and soil temperature sensors (SHT10 and AM2315). The Feather Huzzah reports data to an Adafruit IO dashboard once every 40 seconds. He compared air temperatures and soil temperatures between an uncovered and subsequently mulch-covered basin in his backyard over time. He executed this experiment by measuring the temperature response before and after an intense summer monsoon, and then applying mulch to the basin to see how temperature dynamics would change. His experiment demonstrated that a thin layer of mulch can lower soil temperatures by 12 degrees Fahrenheit, thus reducing soil-water evaporation. He concluded that mulch can serve as an important tool to decrease irrigation demand, while strengthening climate change resiliency in the desert Southwest. He will soon be adding Stemma Soil sensors to his basin to measure water movement in shallow and deep-soil profiles over time.
Equipment for these experiments was purchased by ADEQ and will eventually be used for evaluating best-management practices supported by EPA Clean Water Act grants (Region 9). Thanks to ADEQ for supporting these innovative experiments.
If you’d like more details, the latest chapter of this experiment is posted here:
https://youtu.be/kGVjin8qyp0
You can monitor his Adafruit IO dashboard here:
https://io.adafruit.com/biod101/dashboa ... ensor-test
Equipment used:
Assembled Adafruit Feather HUZZAH with ESP8266 With Headers
https://www.adafruit.com/product/2821
Assembled Terminal Block Breakout
https://www.adafruit.com/product/2926
SHT-10 Mesh-protected Weather-proof Temperature/Humidity Sensor
https://www.adafruit.com/product/1298
AM2315 - Encased I2C Temperature/Humidity Sensor
https://www.adafruit.com/product/1293
USB / DC / Solar Lithium Ion/Polymer charger - v2
https://www.adafruit.com/product/390
Large 6V 3.5W Solar panel - 3.5 Watt
https://www.adafruit.com/product/500
Lithium Ion Polymer Battery - 3.7v 2500mAh
https://www.adafruit.com/product/328
10K Precision Epoxy Thermistor - 3950 NTC
https://www.adafruit.com/product/372
Adafruit Perma-Proto Half-sized Breadboard PCB - Single
https://www.adafruit.com/product/1609
Code is posted under chapter 29 at this link:
http://www.biod101.com/arduino/part2.html
Coming soon:
Adafruit STEMMA Soil Sensor - I2C Capacitive Moisture Sensor
https://www.adafruit.com/product/4026
biod101
Re: Adafruit IO is Helping Tucson, Arizona Evaluate Strategi
by franklin97355 on Sat Aug 15, 2020 7:30 pm
Thank you, we will take look at it.
franklin97355
by languer on Sat Aug 15, 2020 10:07 pm
biod101 wrote:Hello,
Very happy to see UofA and Adafruit working together. Go Wildcats.
languer
by biod101 on Tue Aug 18, 2020 6:18 pm
Thanks! UA is my Alma Mater (MS in Hydrology) so I appreciate knowing we have other Wildcats in the Adafruit-sphere.
biod101
by brubell on Tue Aug 25, 2020 10:33 am
brubell
