Esp32 + Adsl Wifi + Network Disconnected
by Kitkate on Thu Aug 20, 2020 7:39 pm
So im using my esp32 devkit c to connect to the adafruit io server, the problem is that on cellular networks (4g,3g) it works perfectly but when i try to use it with my adsl modem it only shows network disconnected, any particular reason why? . Before i used to access a blynk app (an android/ios iot app) with the same wifi modem and never faced such a problem.
P. S I have enabled io. statustext to debug, sometimes it is network disconnected and sometimes it is idle..waiting etc.
Kitkate
Re: Esp32 + Adsl Wifi + Network Disconnected
by brubell on Mon Aug 24, 2020 10:48 am
Ok - this sounds like a network issue to me. let's try a few things:
1) Are you able to connect with another hotspot/wifi network (such as your cell phone)?
2) Can you run this sketch and connect to Adafruit IO? https://github.com/adafruit/Adafruit_MQ ... sp8266.ino
brubell
by Kitkate on Sun Sep 06, 2020 3:52 pm
1) yes i can easily connect with hotspots and other wifi networks. The problem is indeed with my wifi network as i have changed the board but the problem still persists. Also, the code in this link also works well https://circuits4you.com/2019/01/05/con ... i-network/
2) i have an esp32 so i doubt the esp8266 code would work
Kitkate
by Kitkate on Sun Sep 06, 2020 3:56 pm
do you need to know any details about my wifi network?, i can configure it manually if i need to add anything. My modem is an older one using WPA2-PSK encryption.
Kitkate
by brubell on Mon Sep 07, 2020 10:39 am
Ok, what code example are you using?
Could you copy and paste this below?
brubell
