Base64 MQTT ERROR: data missing required value
by regenerativa on Tue Aug 25, 2020 6:26 pm
I'm trying to send a photo from ESP32CAM to Adafruit IO:
- History on Adafruit IO feed is turned OFF
- Image is formatted to 600x800, JPEG
- Image is converted to base64 string < 104200
- Data is sent using cameraFeed -> save(image)
After sending, Adafruit IO says: "MQTT ERROR: error saving data on xxx/feeds/image, data missing required value"
Code Below:
#include "esp_camera.h"
#include <base64.h>
#include "ioconfig.h" //Adafruit IO and Wifi
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//Setup MQTT Feed
AdafruitIO_Feed *cameraFeed = io.feed("camera");
Serial.begin(9600);
delay(3000);
Serial.setDebugOutput(true);
Serial.println();
Serial.println("CAMERA TEST");
Serial.println();
#include "camera_pins.h"
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 10000000; // was at 20
config.pixel_format = PIXFORMAT_JPEG;
config.frame_size = FRAMESIZE_SVGA; //800 x 600 necessary for Adafruit IO
config.jpeg_quality = 12;
config.fb_count = 1;
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
//Connect to io.adafruit.com
Serial.print("Connecting to WiFi & MQTT Server");
io.connect();
//wait for a connection
while (io.status() < AIO_CONNECTED)
Serial.print(".");
delay(3000);
//We are connected
Serial.println();
Serial.println(io.statusText());
Serial.println();
Serial.println("Taking picture");
delay(1000);
//io.run() is required for all Adafruit IO sketches
io.run();
delay(5000);
// Capture picture
camera_fb_t * fb = NULL;
fb = esp_camera_fb_get();
if(!fb) {
Serial.println("Camera capture failed");
return;
size_t size = fb->len;
String image = base64::encode((uint8_t *) fb->buf, fb->len);
Serial.println(image);
Serial.println("Uploading to Adafruit IO");
delay(5000);
unsigned int length();
if (image.length()>102400) {
Serial.println("Image size too big");
return;
//send data to Adafruit IO feeds
cameraFeed->save(image);
delay(30000);
regenerativa
Re: Base64 MQTT ERROR: data missing required value
by brubell on Wed Aug 26, 2020 12:32 pm
You may want to try increasing the maxbuffer size
https://github.com/adafruit/Adafruit_MQ ... QTT.h#L110
brubell
by regenerativa on Thu Aug 27, 2020 2:55 pm
Thanks for your reply!
How would I go about doing this?
*Sorry total noob here
regenerativa
by brubell on Fri Aug 28, 2020 10:13 am
There's an identical discussion going on over on this thread: viewtopic.php?f=56&t=163931&p=826417#p826417
I'll continue troubleshooting over there to keep the discussion in one place.
brubell
