Fona 32u4 multiple_feeds
by blang on Tue Sep 01, 2020 10:30 am
Hi!
I want to build a GSM-based weather station, but I am unable to get the adafruio_03_multiple_feeds example to run on the Feather Fona 32u4. Commenting out all feeds but one works, as soon as I add a second feed the Feather seems to hang, I don't get any serial console output any more (the COM-port vanishes in the device manager and windows does the ding-dong-sound), also flashing a new sketch is only possible with double clicking the reset button and using DFU mode. I also tried other examples from the Adafruit IO library with the same behavior - single feed ok, 1+N feeds Feather hangs.
Can any body else verify this behavior and/or offer any possible solution?
blang
Re: Fona 32u4 multiple_feeds
by brubell on Mon Sep 07, 2020 9:58 am
Does the same USB disconnection occur with this sketch, too? Similar sketch - uses two feeds
https://github.com/adafruit/Adafruit_MQ ... t_fona.ino
brubell
by blang on Wed Sep 09, 2020 10:14 am
The mqtt-example does compile and run, no issues with the serial output, but it seems I don't get any network connection with it, so I never ever get to publish/subscribe
15:04:36.121 -> Adafruit FONA MQTT demo
15:04:41.132 -> Initializing FONA....(May take 3 seconds)
15:04:41.234 -> Attempting to open comm with ATs
15:04:41.301 -> ---> AT
15:04:41.805 -> <---
15:04:41.872 -> ---> AT
15:04:42.383 -> <---
15:04:42.954 -> ---> AT
15:04:43.257 -> <--- AT
15:04:43.291 -> ---> AT
15:04:43.325 -> <--- AT
15:04:43.393 -> ---> ATE0
15:04:43.428 -> <--- ATE0
15:04:43.565 -> ---> ATE0
15:04:43.598 -> <--- OK
15:04:43.632 -> ---> AT+CVHU=0
15:04:43.701 -> <--- OK
15:04:43.835 -> ---> ATI
15:04:44.410 -> <--- SIM800 R13.08
15:04:44.410 ->
15:04:44.410 -> OK
15:04:44.410 ->
15:04:44.410 -> RDY
15:04:44.410 ->
15:04:44.410 -> +CFUN: 1
15:04:44.410 ->
15:04:44.410 -> ---> AT+GMM
15:04:45.020 -> <--- SIMCOM_SIM800H
15:04:45.020 ->
15:04:45.020 -> OK
15:04:45.020 ->
15:04:45.020 -> +CPIN: READY
15:04:45.020 ->
15:04:45.054 -> ---> AT+CPMS="SM","SM","SM"
15:04:45.122 -> <--- ERROR
15:04:45.156 -> FONA is OK
15:04:45.156 -> Checking for network...
15:04:45.224 -> ---> AT+CREG?
15:04:45.291 -> <--- +CREG: 0,2
15:04:45.831 -> ---> AT+CREG?
15:04:45.900 -> <--- +CREG: 0,2
15:04:46.476 -> ---> AT+CREG?
15:04:46.510 -> <--- +CREG: 0,2
15:04:47.086 -> ---> AT+CREG?
15:04:47.154 -> <--- +CREG: 0,2
15:04:47.695 -> ---> AT+CREG?
15:04:47.763 -> <--- +CREG: 0,2
15:04:48.306 -> ---> AT+CREG?
15:04:48.374 -> <--- +CREG: 0,2
15:04:48.914 -> ---> AT+CREG?
15:04:48.984 -> <--- +CREG: 0,2
15:04:49.527 -> ---> AT+CREG?
15:04:49.596 -> <--- +CREG: 0,2
15:04:50.169 -> ---> AT+CREG?
15:04:50.203 -> <--- +CREG: 0,2
15:04:50.778 -> ---> AT+CREG?
15:04:50.846 -> <--- +CREG: 0,2
15:04:51.388 -> ---> AT+CREG?
15:04:51.455 -> <--- +CREG: 0,2
15:04:51.998 -> ---> AT+CREG?
15:04:52.064 -> <--- +CREG: 0,2
15:04:52.604 -> ---> AT+CREG?
15:04:52.674 -> <--- +CREG: 0,5
15:04:53.250 -> ---> AT+CREG?
15:04:53.284 -> <--- +CREG: 0,5
15:04:53.862 -> ---> AT+CREG?
15:04:53.896 -> <--- +CREG: 0,5
15:04:54.468 -> ---> AT+CREG?
15:04:54.536 -> <--- +CREG: 0,5
15:04:55.081 -> ---> AT+CREG?
15:04:55.150 -> <--- +CREG: 0,5
15:04:55.691 -> ---> AT+CREG?
15:04:55.759 -> <--- +CREG: 0,5
15:04:56.306 -> ---> AT+CREG?
15:04:56.374 -> <--- +CREG: 0,5
15:04:56.918 -> ---> AT+CREG?
15:04:56.986 -> <--- +CREG: 0,5
15:04:57.561 -> ---> AT+CREG?
15:04:57.594 -> <--- +CREG: 0,5
15:04:58.172 -> ---> AT+CREG?
15:04:58.239 -> <--- +CREG: 0,5
15:04:58.781 -> ---> AT+CREG?
The Fona-Test example https://github.com/adafruit/Adafruit_FO ... NAtest.ino works
blang
by brubell on Wed Sep 09, 2020 10:41 am
You may want to check with your carrier if data is enabled for that SIM card.
brubell
by blang on Fri Sep 11, 2020 10:14 am
Yep, another SIM card did the trick for MQTT with multiple feeds - I had a free 20MB a day SIM which seems to have gotten deactivated after not using it for more than a year.
I am pulling the BME280 data and anemometer/wind vane via i2c from a Arduino Pro Mini as I might not have enough IOs on the FONA
  Adafruit MQTT Library FONA Example
  Designed specifically to work with the Adafruit FONA
  ----> http://www.adafruit.com/products/1946
  ----> http://www.adafruit.com/products/1963
  ----> http://www.adafruit.com/products/2468
  ----> http://www.adafruit.com/products/2542
  These cellular modules use TTL Serial to communicate, 2 pins are
  required to interface.
  products from Adafruit!
  MIT license, all text above must be included in any redistribution
#include <Adafruit_SleepyDog.h>
#include <SoftwareSerial.h>
#include "Adafruit_FONA.h"
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_FONA.h"
#include <EasyTransferI2C.h>
//create object
EasyTransferI2C ET;
struct RECEIVE_DATA_STRUCTURE {
  //put your variable definitions here for the data you want to send
  //THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO
  float temperature;
  float pressure;
  float humidity;
  float windspeed;
  int16_t winddirection;
//give a name to the group of data
RECEIVE_DATA_STRUCTURE weatherdata;
//define slave i2c address
#define I2C_SLAVE_ADDRESS 9
float barometer_val = 0;
float batvoltage_val = 0;                                     // Floating values to be transmitted via MQTT
float humidity_val = 0;
float solarvoltage_val = 0;
float temperature_val = 0;
int winddirection_val = 0;
float windspeed_val = 0;
uint8_t precision = 2;
/*************************** FONA Pins ***********************************/
// Default pins for Feather 32u4 FONA
#define FONA_RX  9
#define FONA_TX  8
#define FONA_RST 4
#define FONA_RI  7
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
/************************* WiFi Access Point *********************************/
// Optionally configure a GPRS APN, username, and password.
// You might need to do this to access your network's GPRS/data
// network.  Contact your provider for the exact APN, username,
// and password values.  Username and password are optional and
// can be removed, but APN is required.
#define FONA_APN       ""
#define FONA_USERNAME  ""
#define FONA_PASSWORD  ""
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883
#define AIO_USERNAME    "xxx"
#define AIO_KEY         "xxx"
/************ Global State (you don't need to change this!) ******************/
// Setup the FONA MQTT class by passing in the FONA class and MQTT server and login details.
Adafruit_MQTT_FONA mqtt(&fona, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
// You don't need to change anything below this line!
#define halt(s) { Serial.println(F( s )); while(1);  }
// FONAconnect is a helper function that sets up the FONA and connects to
// the GPRS network. See the fonahelper.cpp tab above for the source!
boolean FONAconnect(const __FlashStringHelper *apn, const __FlashStringHelper *username, const __FlashStringHelper *password);
/****************************** Feeds ***************************************/
Adafruit_MQTT_Publish barometer_feed = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/barometer");
Adafruit_MQTT_Publish batvoltage_feed = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/batvoltage");
Adafruit_MQTT_Publish humidity_feed = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/humidity");
Adafruit_MQTT_Publish solarvoltage_feed = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/solarvoltage");
Adafruit_MQTT_Publish temperature_feed = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/temperature");
Adafruit_MQTT_Publish winddirection_feed = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/winddirection");
Adafruit_MQTT_Publish windspeed_feed = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/windspeed");
/*************************** Sketch Code ************************************/
// probe pins
int sensorPowerPin = 0;                            // GPIO pin that powers ProMini before measurements
int batteryVoltagePin = A0;                             // ADC pin that receives battery voltage data
int solarVoltagePin = A1;                             // ADC pin that receives solar voltage data
// How many transmission failures in a row we're willing to be ok with before reset
uint8_t txfailures = 0;
#define MAXTXFAILURES 3
void receive(int numBytes) {}
// Read temperature from temperature probe
void read_sensors(void) {
  float vbat_out = 0;                                // Voltage output from battery
  float vsolar_out = 0;                             // Voltage output from solar
  for (int i = 0; i < 20; i++) {
    delay(1);                                     // Wait 1 ms for sensor to stabilize
    vbat_out += analogRead(0);                       // Read the input pin and add to multiple measurement aggregate
  vbat_out /= 20;                                    // Divide by # of measurements to find average value. Done to smooth noisy measurements
    vsolar_out += analogRead(1);                       // Read the input pin and add to multiple measurement aggregate
  vsolar_out /= 20;                                    // Divide by # of measurements to find average value. Done to smooth noisy measurements
  vbat_out *= .0064;
  vsolar_out *= .0032;                                 // Convert ADC points to volts (3.3/1023 because AREF is set to 3.3V)
  batvoltage_val = vbat_out;
  solarvoltage_val = vsolar_out;
  digitalWrite(sensorPowerPin, HIGH);             // Power-on sensor
  delay(5000);
  //check and see if a data packet has come in.
  if (ET.receiveData()) {
    //this is how you access the variables. [name of the group].[variable name]
    //since we have data:
    Serial.println();
    Serial.print("Pressure = ");
    Serial.print(weatherdata.pressure);
    Serial.println(" mbar");
    barometer_val = weatherdata.pressure;
    Serial.print("Battery = ");
    Serial.print(batvoltage_val);
    Serial.println(" V");
    Serial.print("Humidity = ");
    Serial.print(weatherdata.humidity);
    Serial.println(" %");
    humidity_val = weatherdata.humidity;
    Serial.print("Solar = ");
    Serial.print(solarvoltage_val);
    Serial.print("Temperature = ");
    Serial.print(weatherdata.temperature);
    Serial.println(" *C");
    temperature_val = weatherdata.temperature;
    Serial.print("Winddirection = ");
    Serial.print(weatherdata.winddirection);
    Serial.println(" Degrees");
    winddirection_val = weatherdata.winddirection;
    Serial.print("Windspeed = ");
    Serial.print(weatherdata.windspeed);
    Serial.println(" m/s");
    windspeed_val = weatherdata.windspeed;
    Serial.println();
    digitalWrite(sensorPowerPin, LOW);              // Power-off sensor
    Watchdog.reset();
  while (!Serial);
  // Watchdog is optional!
  //Watchdog.enable(8000);
  Serial.begin(115200);
  Serial.println(F("Adafruit FONA MQTT weather"));
  Watchdog.reset();
  delay(5000);  // wait a few seconds to stabilize connection
  Watchdog.reset();
  pinMode(sensorPowerPin, OUTPUT);
  Wire.begin(I2C_SLAVE_ADDRESS);
  //start the library, pass in the data details and the name of the serial port. Can be Serial, Serial1, Serial2, etc.
  ET.begin(details(weatherdata), &Wire);
  //define handler function on receiving data
  Wire.onReceive(receive);
  // Initialise the FONA module
  while (! FONAconnect(F(FONA_APN), F(FONA_USERNAME), F(FONA_PASSWORD))) {
    Serial.println("Retrying FONA");
  Serial.println(F("Connected to Cellular!"));
  Watchdog.reset();
  Watchdog.reset();
  //digitalWrite(batteryVoltagePin, LOW);           // Set pull-up on analog input pin
  //digitalWrite(solarVoltagePin, LOW);           // Set pull-up on analog input pin
  barometer_val = 0;
  humidity_val = 0;
  windspeed_val = 0;
  // Make sure to reset watchdog every loop iteration!
  Watchdog.reset();
  // Ensure the connection to the MQTT server is alive (this will make the first
  // connection and automatically reconnect when disconnected).  See the MQTT_connect
  // function definition further below.
  MQTT_connect();
  Watchdog.reset();
  // Now we can publish stuff!
  read_sensors();
  Serial.print(F("\nSending val "));
  if (! barometer_feed.publish(barometer_val, precision) || ! batvoltage_feed.publish(batvoltage_val, precision) || ! humidity_feed.publish(humidity_val, precision) || ! solarvoltage_feed.publish(solarvoltage_val, precision) || ! temperature_feed.publish(temperature_val, precision) || ! winddirection_feed.publish(winddirection_val, precision) || ! windspeed_feed.publish(windspeed_val, precision)) {
    Serial.println(F("Failed"));
    txfailures++;
  } else {
    Serial.println(F("OK!"));
    txfailures = 0;
  delay(60000);
  Watchdog.reset();
  // ping the server to keep the mqtt connection alive, only needed if we're not publishing
  //if(! mqtt.ping()) {
  //  Serial.println(F("MQTT Ping failed."));
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
    Serial.println(mqtt.connectErrorString(ret));
    Serial.println("Retrying MQTT connection in 5 seconds...");
    mqtt.disconnect();
    delay(5000);  // wait 5 seconds
  Serial.println("MQTT Connected!");
blang
