IO Connect status showing "Disconnected from Adafruit IO"
by Maverick366 on Sat Sep 12, 2020 11:42 pm
So, I've followed this tutorial to the letter:
https://learn.adafruit.com/adafruit-io- ... y/overview
But once I get to the step to load it all up to my board and send the readings to https://io.adafruit.com/ I simply get the status error in the serial monitor "Disconnected from Adafruit IO".
I went to the site and checked my IO username and key and copied that into my config.h file. I even regenerated it just in case, but still no luck. I'm connected to the wifi so that doesn't seem to be the issue, so I'm at a loss.
Any help would be appreciated.
Maverick366
Re: IO Connect status showing "Disconnected from Adafruit IO
by Maverick366 on Sun Sep 13, 2020 2:19 am
So after pouring over this and testing, it looks like my issue was associated with the update of the Adafruit IO SSL cert. So I upgraded all of my installed libraries in the libraries manager and then I made sure under Tools-->Erase Flash, I had it set to Sketch + Wifi Settings.
Once I ran that, it cleaned up my issue. Hope this helps.
Maverick366
