🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
Deleting multiple data points
by potokslow on Thu Oct 08, 2020 7:06 am
I'd like to delete multiple data points from a feed (few hundred items).
According to https://learn.adafruit.com/adafruit-io- ... -feed-data - tick boxes should be available allowing to select and delete multiple points at a time, however it's not the case for my account.
Is there some special condition to enable this functionality?
Thank you
potokslow
Re: Deleting multiple data points
by brubell on Fri Oct 09, 2020 9:37 am
The screenshots on that page are from a previous version of Adafruit IO.
There's no way to remove all data from a feed at the same time. Feed deletion is an API action (https://io.adafruit.com/api/docs/#delete-data-point) and is therefore limited to your account's data rate (30 or 60 data points per minute for IO Free and IO Plus, respectively).
You may want to create a script which uses the delete data point api endpoint (https://io.adafruit.com/api/docs/#delete-data-point) to remove data.
brubell
by vamo on Wed Oct 14, 2020 3:13 am
I have the same problem.
I have realized an acquisition system and the data are transmitted on adafruit io feeds.
In the dashboard I would like to display only the last 24 hours of data.
This is possible in the "line chart" modules, but instead in the "map" module the setting of the represented period ("Hours of History - 0 for realtime") is completely ignored, and all data in the feed are represented.
To clean the representation in the "map" module it is not even possible to delete the entire feed, otherwise the "map" module using that feed is automatically deleted from the dashboard after the deletion of the feed.
Currently, in order to delete the past data, I have to edit the dashboard to temporarily associate the "map" module to a different feed, then delete the feed to clean, then recreate it, then re-associate the "map" module to the original recreated feed (now empty).
Very very cumbersome...
Is it possible to delete directly and in a single operation a range of data from a feed? Via web or API?
many many thanks...
vamo
by brubell on Fri Oct 16, 2020 4:09 pm
I've escalated this to our web team and they'll be taking a look at it on the other thread you posted.
No, not currently.
brubell
by vamo on Mon Oct 19, 2020 7:38 am
Hi Brent.
Thanks for the reply.
Maybe the best solution could be to finally solve the problem that the setting of the represented period ("Hours of History - 0 for realtime") is ignored in the "map" module, and all data in the feed are represented. This could solve in a better way.
Do you know if the web team is working on it..?
Many thanks again,
Valerio
vamo
by brubell on Wed Oct 21, 2020 11:07 am
I'm not sure what you mean by this - could you explain more?
brubell
by vamo on Wed Oct 21, 2020 1:53 pm
Brent,
I can confirm, in my dashboard I have a map module; the setting of the represented period ("Hours of History - 0 for realtime") is ignored, and all data in the feed are represented.
See also the forum
viewtopic.php?f=56&t=162021
where it was reported by other people.
This is why I was trying to find a fast way to clear the data, or else i'm forced to see a map having days and days of data, with several routes overlapping...
Is the web group informed of this...?
Correctly implementing the "Hours of History - 0 for realtime" could be a good feature to work on.
Thanks again,
Valerio
vamo
by chrispynz4 on Fri Oct 30, 2020 12:19 am
This has also been problematic for me for a long time.
If the hours of history is zero then the map should only display the current position and no trail at all. Preferably the current position could be shown as an icon, because if it's just a tiny blue dot it will be nearly invisible.
The hours of history configuration setting doesn't seem to work at all. A setting of 1 hour of history would be better than nothing and should only show the last hour, instead of the days and days of tracks which it currently shows. There's too much activity for days and days worth of activity to be meaningful on a map. I don't care where it's been, I care where it is .
It's impossible to tell where the device is right now, because there is multiple days of tracks in there.
It doesn't matter if the value is 0 or 1 or any other number, there is no difference to the map.
chrispynz4
by vamo on Fri Oct 30, 2020 4:56 am
I cannot think that adafruit is not aware of this problem. As soon as anyone starts using the "map" module, he certainly realizes that it is impossible to set which period is displayed. So I think that certainly the adafruit web team is working on this.
The ideal would be to be able to control the displayed period directly from a drop down menu on the module itself, similar to the one in the "line chart" when in edit mode, see figure
Brent, please, give us good news...!
Kind regards,
VALERIO
vamo
by brubell on Fri Oct 30, 2020 9:26 am
Vamo and chrispynz4,
I've been able to replicate this issue on my end and have escalated it to the web team. I'll post here again when I have an update.
- Brent R.
brubell
