Re: Deleting multiple data points
I'd like to delete multiple data points from a feed (few hundred items).
To clean the representation in the "map" module it is not even possible to delete the entire feed, otherwise the "map" module using that feed is automatically deleted from the dashboard after the deletion of the feed.
Is it possible to delete directly and in a single operation a range of data from a feed? Via web or API?
Maybe the best solution could be to finally solve the problem that the setting of the represented period ("Hours of History - 0 for realtime") is ignored in the "map" module, and all data in the feed are represented. This could solve in a better way.
makinitwork wrote:Hi Folks,
Thanks for all that fixed this. Just so I'm clear on what is fixed, is it the ability to set Hours of History on a Dashboard and then subsequently have the dashboard display all the data in that hour range? Or was the fix the ability to delete multiple data points?
The reason I ask is that I edited my existing dashboard setting my hours of history to 1 however it is still displaying all data points.
