NeoPixel Not Powering
by PhillyDrummer on Thu Oct 15, 2020 9:36 pm
We are connecting the NeoPixel RGB Neon-like LED Flex Strip as seen in the documentation and videos. The strip is not lighting up.
Is there an issue with this wiring or is our product defective?
Thank you,
David
PhillyDrummer
Re: NeoPixel Not Powering
by dastels on Thu Oct 15, 2020 10:16 pm
What are you driving it with and what code are you using?
dastels
by PhillyDrummer on Thu Oct 15, 2020 10:56 pm
We tried a few configurations.
Directly driving with an ATmega328P
and
following the breadboard setup under (Raspberry Pi Wiring with Level Shifting Chip):
https://learn.adafruit.com/neopixels-on ... 7OSGYt0ir0
Using a:
http://www.arduinostarterskit.com/sale- ... duino.html
PhillyDrummer
by dastels on Fri Oct 16, 2020 11:26 am
You don't need a level shifter if you are driving the NeoPixels with a 5v logic signal (which a classic Arduino (or copy) uses), only for 3.3v logic (which the Pi uses, hence needing a level shifter for it). Make sure all your grounds are connected together.
dastels
by PhillyDrummer on Sat Oct 17, 2020 10:33 am
Looks like we might have a bad connection. We are running the code that should be cycling through the three colors. Only red lights up and it is very dim.
If the NeoPixel is defective, can you assist with a replacement?
Demo:
https://youtu.be/2G2mJWRAWsA
Thanks<
David
PhillyDrummer
by dastels on Sat Oct 17, 2020 11:13 am
Everything you've done should just work.
Please email support@adafruit.com with a link to this thread, your order number, and request the replacement of one NeoPixel RGB Neon-like LED Flex Strip.,
dastels
