extra stepper servo shield for rambo
by moleupnorth on Fri Oct 16, 2020 8:33 am
I have a Rambo 3 and it has all its stepper and servo channels in use.
Can I add an AdaFruit Motor shield(s), stepper and servo, to the Rambo and enable control of extra motors using Marlin
if yes, what pin connections on the Rambo v1.3
moleupnorth
Re: extra stepper servo shield for rambo
by adafruit_support_bill on Fri Oct 16, 2020 9:17 am
You might be able to get it to work, but it would not be seamless. The motor shield uses an i2c interface with a very shield-specific protocol, so you would need to somehow integrate the Adafruit library with your Marlin software. The interface pins for steppers would be SDA and SCL. Servo pins are a direct pass-through. You could use any free digital pin from the Rambo.
