Haptic Headband
Haptic Headband
by ynava on Sat Oct 17, 2020 1:53 am
I am trying to verify the code for the Haptic Headband from 2015, however, I keep getting the error which I have attached below. I was hoping for guidance on what I could do to solve this issue.
Error compiling for board Arduino Uno.
libraries\Adafruit_DRV2605_Library\Adafruit_DRV2605.cpp.o (symbol from plugin): In function `Adafruit_DRV2605::Adafruit_DRV2605()':
(.text+0x0): multiple definition of `Adafruit_DRV2605::Adafruit_DRV2605()'
sketch\Adafruit_DRV2605.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `Adafruit_DRV2605::readRegister8(unsigned char)'
(.text+0x0): multiple definition of `Adafruit_DRV2605::writeRegister8(unsigned char, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_DRV2605::init()'
(.text+0x0): multiple definition of `Adafruit_DRV2605::begin(TwoWire*)'
(.text+0x0): multiple definition of `Adafruit_DRV2605::setWaveform(unsigned char, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_DRV2605::selectLibrary(unsigned char)'
(.text+0x0): multiple definition of `Adafruit_DRV2605::go()'
(.text+0x0): multiple definition of `Adafruit_DRV2605::stop()'
(.text+0x0): multiple definition of `Adafruit_DRV2605::setMode(unsigned char)'
(.text+0x0): multiple definition of `Adafruit_DRV2605::setRealtimeValue(unsigned char)'
(.text+0x0): multiple definition of `Adafruit_DRV2605::useERM()'
(.text+0x0): multiple definition of `Adafruit_DRV2605::useLRA()'
collect2.exe: error: ld returned 1 exit status
exit status 1
I also wanted to ask if this project will require a breadboard to complete. I did not see it on the list and was confused about this.
Thank you and I would truly appreciate any help I could get.
ynava
Re: Haptic Headband
by dastels on Sat Oct 17, 2020 2:40 pm
You have the DRV2605 code locally as well as installed as a library. The linker is finding it in both places and thus giving up in confusion. I suggest you use the installed library. Make sure all your libraries are up to date.
dastels
Re: Haptic Headband
by ynava on Sat Oct 17, 2020 9:56 pm
Thank you so much!
ynava
