🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
Error when running environmental_monitor.py
by trent_darkside on Wed Nov 04, 2020 11:36 am
Hello Adafruit,
I am experiencing an error when trying to run environmental_monitor.py on the raspberry pi zero w.
The Adafruit BME280 Temp Humidity Pressure Sensor, Adafruit SGP30 Air Quality Sensor Breakout,
and Adafruit VEML6070 UV Index Sensor Breakout are connected to i2c on the Pi Zero W.
The Environmental Monitor Dashboard has been created as instructed at https://learn.adafruit.com/adafruit-io- ... r/overview
This dashboard is not displaying any data from the sensors connected to the pi zero.
I have recently subscribed to Adafruit IO +
What could be causing the issue?
Sensors connected to i2c on pi are detected.
pi@breadboardpi:~ $ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- 38 39 -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- 58 -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- 77
Here is the error.
pi@breadboardpi:~ $ python3 environmental_monitor.py
Reading sensors...
File "environmental_monitor.py", line 101, in <module>
uv_data = sample_VEML()
File "environmental_monitor.py", line 91, in sample_VEML
uv_raw = uv.read
AttributeError: 'VEML6070' object has no attribute 'read'
Here is the environmental_monitor.py code provided at https://learn.adafruit.com/adafruit-io- ... ython-code
'environmental_monitor.py'
Example of sending I2C sensor data
from multiple sensors to Adafruit IO.
Tutorial Link: https://learn.adafruit.com/adafruit-io-air-quality-monitor
Adafruit invests time and resources providing this open source code.
Please support Adafruit and open source hardware by purchasing
products from Adafruit!
Author(s): Brent Rubell for Adafruit Industries
Copyright (c) 2018 Adafruit Industries
Licensed under the MIT license.
All text above must be included in any redistribution.
Dependencies:
    - Adafruit_Blinka (CircuitPython, on Pi.)
        (https://github.com/adafruit/Adafruit_Blinka)
    - Adafruit_CircuitPython_SGP30.
        (https://github.com/adafruit/Adafruit_CircuitPython_SGP30)
    - Adafruit_CircuitPython_VEML6070.
        (https://github.com/adafruit/Adafruit_CircuitPython_VEML6070)
    - Adafruit_CircuitPython_BME280.
        (https://github.com/adafruit/Adafruit_CircuitPython_BME280)
# Import standard python modules
import time
# import Adafruit Blinka
import board
import busio
# import CircuitPython sensor libraries
import adafruit_sgp30
import adafruit_veml6070
import adafruit_bme280
# import Adafruit IO REST client
from Adafruit_IO import Client, Feed, RequestError
# loop timeout, in seconds.
LOOP_DELAY = 10
# Set to your Adafruit IO key.
# Remember, your key is a secret,
# so make sure not to publish it when you publish this code!
ADAFRUIT_IO_KEY = 'YOUR_AIO_KEY'
# Set to your Adafruit IO username.
# (go to https://accounts.adafruit.com to find your username)
ADAFRUIT_IO_USERNAME = 'YOUR_AIO_USERNAME'
# Create an instance of the REST client
aio = Client(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
try: # if we already have the feeds, assign them.
    tvoc_feed = aio.feeds('tvoc')
    eCO2_feed = aio.feeds('eco2')
    uv_feed = aio.feeds('uv')
    temperature_feed = aio.feeds('temperature')
    humidity_feed = aio.feeds('humidity')
    pressure_feed = aio.feeds('pressure')
    altitude_feed = aio.feeds('altitude')
except RequestError: # if we don't, create and assign them.
    tvoc_feed = aio.create_feed(Feed(name='tvoc'))
    eCO2_feed = aio.create_feed(Feed(name='eco2'))
    uv_feed = aio.create_feed(Feed(name='uv'))
    temperature_feed = aio.create_feed(Feed(name='temperature'))
    humidity_feed = aio.create_feed(Feed(name='humidity'))
    pressure_feed = aio.create_feed(Feed(name='pressure'))
    altitude_feed = aio.create_feed(Feed(name='altitude'))
# Create busio I2C
i2c = busio.I2C(board.SCL, board.SDA, frequency=100000)
# Create VEML6070 object.
uv = adafruit_veml6070.VEML6070(i2c)
# Create BME280 object.
bme280 = adafruit_bme280.Adafruit_BME280_I2C(i2c)
bme280.sea_level_pressure = 1013.25
# Create SGP30 object using I2C.
sgp30 = adafruit_sgp30.Adafruit_SGP30(i2c)
sgp30.iaq_init()
sgp30.set_iaq_baseline(0x8973, 0x8aae)
# Sample VEML6070
def sample_VEML():
    for j in range(10):
      uv_raw = uv.read
    return uv_raw
while True:
    print('Reading sensors...')
    # Read SGP30.
    eCO2_data = sgp30.eCO2
    tvoc_data = sgp30.TVOC
    # Read VEML6070.
    # Read BME280.
    temp_data = bme280.temperature
    # convert temperature (C->F)
    temp_data = int(temp_data) * 1.8 + 32
    humid_data = bme280.humidity
    pressure_data = bme280.pressure
    alt_data = bme280.altitude
    print('sending data to adafruit io...')
    # Send SGP30 Data to Adafruit IO.
    print('eCO2:', eCO2_data)
    aio.send(eCO2_feed.key, eCO2_data)
    print('tvoc:', tvoc_data)
    aio.send(tvoc_feed.key, tvoc_data)
    time.sleep(2)
    # Send VEML6070 Data to Adafruit IO.
    print('UV Level: ', uv_data)
    aio.send(uv_feed.key, uv_data)
    time.sleep(2)
    # Send BME280 Data to Adafruit IO.
    print('Temperature: %0.1f C' % temp_data)
    aio.send(temperature_feed.key, temp_data)
    print("Humidity: %0.1f %%" % humid_data)
    aio.send(humidity_feed.key, int(humid_data))
    time.sleep(2)
    print("Pressure: %0.1f hPa" % pressure_data)
    aio.send(pressure_feed.key, int(pressure_data))
    print("Altitude = %0.2f meters" % alt_data)
    aio.send(altitude_feed.key, int(alt_data))
    # avoid timeout from adafruit io
    time.sleep(LOOP_DELAY * 60)
Thanks to Adafruit for your support during the pandemic.
Trent
trent_darkside
Re: Error when running environmental_monitor.py
by brubell on Wed Nov 04, 2020 12:01 pm
Hi Trent,
The VEML6070 library has been changed a bit since this code has been published.
I've updated the code and submitted a pull request. Would you be able to test this code and let me know if it works?
https://github.com/adafruit/Adafruit_IO_Python/pull/122
- Brent R.
brubell
by trent_darkside on Wed Nov 04, 2020 2:09 pm
Hi Brent,
Thank you for the response.
I would like to test the updated code. Where can it be found?
This is my first time using AdafruitIO and I have limited experience with python.
trent_darkside
by trent_darkside on Wed Nov 04, 2020 3:07 pm
It's working. Data values have populated the dashboard.
Thank you very much.
Reading sensors...
eCO2: 400
tvoc: 0
UV Level: 0
Temperature: 73.4 C
Humidity: 50.1 %
Pressure: 1031.6 hPa
Altitude = -151.90 meters
Can this code be set to run on boot with the method described at https://learn.adafruit.com/running-prog ... y-computer
or should I let it run and quit the putty ssh session?
trent_darkside
by brubell on Fri Nov 06, 2020 10:24 am
Glad it's working, I'll merge in.
If you want to run on boot, check out this guide instead:
https://learn.adafruit.com/adafruit-min ... -3044386-8
brubell
