Feed Download Results in Blank Values
by fastidioussarah on Mon Nov 09, 2020 10:43 pm
I am very new to Adafruit IO so please excuse me if I am missing something obvious. I have data saved in a feed (with feed history ON, if that matters). When I click the "Download All Data" button and select "Download as CSV", an Excel file comes up with the id, value, feed_id, and created_at columns. The id, feed_id, and created_at columns all appear to be populated correctly, but the value column is completely empty--no data is populated there. The UTC time reported appears to be correct, and the length of the data reported appears to be correct. This is the only data I have recorded within this particular feed.
Can someone please tell me what I am doing wrong? I need to be able to download this data in order to manipulate it in Matlab.
Thank you.
fastidioussarah
Re: Feed Download Results in Blank Values
by brubell on Wed Nov 11, 2020 10:55 am
Could you please file this issue over at http://io.adafruit.com/support. Click Contact Support
Please include the name of the feed(s) you're having issues with so we can check this issue on our end.
- Brent R.
brubell
