FirstFloor322 wrote:FirstFloor322 wrote:the text on the buttons look distorted......sugesstion make the button width adjustable.....also if possible let the buttons retain their position when other one is clicked, they go back to off state when other buttons are clicked
can someone help me with this?? pls.....
I can't reproduce this issue.
Are you saying if you click a toggle button, the others all change? If they are using the same feed, that would be expected behavior. The system will keep them in sync no matter where you change the values.
We'll look into adding width to the toggle buttons, but typically the text is going to look better shortened like "ON and OFF" and you can use the title of the block to say what you are turning off and on.."Living Room Lights".
