IO UI Updated - feedback and issues
Re: IO UI Updated - feedback and issues
by cjdshaw on Wed Nov 18, 2020 7:45 am
It's a small issue, but when a line in a graph changes direction sharply, the thickness makes it appear that it's overshot. For example, this value is going between 0 and 1, but the spikes make it look like it's gone negative
Screenshot 2020-11-18 at 11.41.02.png (7.64 KiB) Viewed 71 times
cjdshaw
by jwcooper on Wed Nov 18, 2020 12:19 pm
biggles4808 wrote:Not sure if the latest version is live yet but the date filtering on individual data feeds is still not working. Black screen when apply filters is clicked. Trying to just filter for the last 7 days
I'll make it more robust, including hints on formatting (and allow more formats), but in the meantime, dates formatted as such should work: 2020-11-19T11:17
jwcooper
by cjdshaw on Wed Nov 18, 2020 1:04 pm
It may be a locale thing, but the page won't let me use ISO8601 formatting. It's locked to dd/mm/yyyy hh:mm, (I'm in the UK) including when I use the calendar widgets
Screenshot 2020-11-18 at 17.01.46.png (25.83 KiB) Viewed 68 times
cjdshaw
by jwcooper on Wed Nov 18, 2020 1:35 pm
Oh, this is a browser issue as well. I see the calendar widgets in chrome, but not firefox. Thanks for the screenshot. Will get this fixed asap.
jwcooper
by biggles4808 on Wed Nov 18, 2020 2:45 pm
As it happens, I am also in the UK, so you might be right and it is a format issue. Also, I am using Chrome.
Cheers
David
biggles4808
by tomtheriverguide on Wed Nov 18, 2020 8:30 pm
I have had text display issues with the 'gauge' type block on my iPhone like others seem to be having.
Otherwise, the changes that I have seen are more aesthetically pleasing to my eye.
IO - Mobile Thermostat.jpg (101.75 KiB) Viewed 57 times
tomtheriverguide
by jwcooper on Thu Nov 19, 2020 12:06 pm
biggles4808 wrote:As it happens, I am also in the UK, so you might be right and it is a format issue. Also, I am using Chrome.
Cheers
David
As a follow-up, I'm unable to reproduce this issue thus far.
I've been testing in chrome with an en_GB.UTF-8 locale. I can reproduce everything visually, but no errors thrown when filtering.
jwcooper
by jwcooper on Thu Nov 19, 2020 12:10 pm
Oh right, this is due to chrome enabling support for datetime-local input types, and firefox not supporting that on desktop yet. I think all of that should work now, in that particular formatting, as the browser will submit the iso8601 format properly for you.
jwcooper
by ArdLab on Fri Nov 20, 2020 10:59 am
As a new user I'm having some trouble with dashboards on my Iphone.
Dashboard on my Mac (Chrome/Safari) are working fine.
A line chart on the dashboard completely blacks out my Iphone screen, a dashboard with 2 swicthes works fine on the Iphone.
Any help would be appreciated.
ArdLab
by sahillyard on Fri Nov 20, 2020 2:34 pm
You might want to reconsider the font used in the floating text boxes used with the graphs. The dark blue font that contains the data on a black background is difficult to read.
sahillyard
by ArdLab on Fri Nov 20, 2020 3:12 pm
The screen goes entirely black, all objects are invisible, hard to believe it would be a font issue but thanks anyway for the suggestion.
ArdLab
by cjdshaw on Fri Nov 20, 2020 3:34 pm
ArdLab wrote:As a new user I'm having some trouble with dashboards on my Iphone.
It completely blanks the screen? Do you have the Safari address bar at the top? What about the Adafruit toolbar? If there's anything on screen, a screenshot would be useful. What version of iOS are you using?
cjdshaw
by cjdshaw on Fri Nov 20, 2020 3:37 pm
sahillyard wrote:You might want to reconsider the font used in the floating text boxes used with the graphs. The dark blue font that contains the data on a black background is difficult to read.
Do you mean in light (non-dark) mode? The dark mode floating boxes are easy to read for me, but the issue is more that in light mode, the floating box bg is still dark, making lots of the text hard to read, particularly the purple one
Screenshot 2020-11-20 at 19.36.20.png (57.47 KiB) Viewed 49 times
cjdshaw
by ArdLab on Fri Nov 20, 2020 5:49 pm
Iphone XR iOS13.3.1
ArdLab
by brubell on Fri Nov 20, 2020 5:51 pm
ArdLab wrote:Image
Iphone XR iOS13.3.1
Hi, this image did not link properly
brubell
