🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
Defective LoRaWAN gateway (TTIG)
by aromring on Tue Nov 17, 2020 12:24 am
Just few days ago I bought from you the much needed item: "The Things Indoor LoRaWAN WiFi Gateway 900 MHz" (PID: 4345). I am afraid the item you sold me is defective.
First, let me answer the obvious questions:
1) Yes, I successfully set the gateway up, it does connect to my wireless router, I can see it on the Attached Devices list, and it answers to pings on my LAN.
2) Yes, I did register it with The Things Network. Yes, the Gateway ID is correct, the frequency plan is correct, the TTN router is correct and I have pictures to prove it (available to Adafruit personnel).
Second, the symptoms (video available to Adafruit personnel):
1) Right after plugging the gateway the green LED flashes at 1 Hz indicating connection attempt to the wireless router. It succeeds in that because the LED flashes change to alternating green and orange colors - this indicates connection attempt to the TTN server. However, this step is not successful and the LED starts flashing green at 4 Hz frequency.
You may rightfully ask "How is it our fault? It's a network problem!" Well, the attached screenshot shows why: One of the TTN users came up with a clever way of diagnosing the problem via a curl command. I repeated the test on my Mac and got the same result: "Not provisioned". This is interpreted as "vendor forgot to unlock the device". In my case vendor is Adafuit... Please advise on what to do next.
Screen Shot 2020-11-15 at 8.45.26 PM.png (149.54 KiB) Viewed 93 times
aromring
Re: Defective LoRaWAN gateway (TTIG)
by djfurie on Tue Nov 17, 2020 11:47 am
I also recently purchased a TTIG from Adafruit, saw the same problem you're seeing, and eventually arrived at the same conclusion.
My forum posts on The Things Network have not generated any replies about what other steps can be taken to debug this.
Edit to add some serial logs:
1970-01-01 00:00:06.230 [SYS:DEBU]   Free Heap: 54768 (min=53256) wifi=1 mh=3 cups=0 tc=0
1970-01-01 00:00:07.236 [SYS:DEBU]   Free Heap: 54768 (min=53256) wifi=1 mh=3 cups=0 tc=0
ip:10.0.5.122,mask:255.255.255.0,gw:10.0.5.1
1970-01-01 00:00:08.240 [SYS:DEBU]   Free Heap: 54768 (min=53256) wifi=5 mh=3 cups=0 tc=0
1970-01-01 00:00:08.248 [CUP:INFO] Stopping TC and starting CUPS
1970-01-01 00:00:08.250 [CUP:INFO] Starting a CUPS session
1970-01-01 00:00:08.259 [CUP:INFO] Connecting to CUPS ... https://mh.sm.tc:7007 (try #1)
1970-01-01 00:00:08.269 [any:INFO] cert. version     : 1
serial number     : 01
issuer name       : CN=Root CA, OU=TrackCentral (ez5Cj0eN), O=TrackNet.io, C=CH
subject name      : CN=Root CA, OU=TrackCentral (ez5Cj0eN), O=TrackNet.io, C=CH
issued  on        : 2018-11-22 10:23:38
expires on        : 2024-11-20 10:23:38
signed using      : ECDSA with SHA256
EC key size       : 256 bits
1970-01-01 00:00:08.294 [AIO:INFO] cups has no cert configured - running server auth and client auth with token
1970-01-01 00:00:08.447 [CUP:VERB] Retrieving update-info from CUPS https://mh.sm.tc:7007...
1970-01-01 00:00:15.074 [SYS:DEBU]   Free Heap: 26088 (min=25584) wifi=5 mh=7 cups=1 tc=0
1970-01-01 00:00:15.595 [any:VERB] Failed to retrieve TCURI from CUPS: (404) Not Found
1970-01-01 00:00:15.598 [AIO:DEBU] [2] HTTP connection shutdown...
1970-01-01 00:00:15.605 [SYS:INFO] sys_inState - Ignoring state transition: 5
1970-01-01 00:00:15.608 [CUP:INFO] Interaction with CUPS failed - retrying in 1m
1970-01-01 00:00:15.612 [TCE:INFO] Starting TC engine
1970-01-01 00:00:15.618 [TCE:ERRO] No TC URI configured
1970-01-01 00:00:15.627 [TCE:INFO] INFOS reconnect backoff 0s (retry 0)
1970-01-01 00:00:15.631 [TCE:ERRO] No TC URI configured
1970-01-01 00:00:15.633 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
djfurie
by AlanMitchell on Tue Nov 17, 2020 10:53 pm
I too am in the same situation with a gateway I just recently received from Adafruit. It connects to my WiFi network (as I verified through my WiFi router), but it does the 4 Hz green flash indicating radio or network problems. I have successfully provisioned a few other LoRaWAN gateways on my network (including another Things Indoor gateway). A fix would be preferable to returning the gateway. Thanks to the rest of you for all your detailed documentation of the problem.
AlanMitchell
by brubell on Wed Nov 18, 2020 12:28 pm
Could you please link the posts to the TTN forum?
brubell
by adafruit2 on Wed Nov 18, 2020 12:42 pm
btw we dont touch these gateways, they come sealed directly from TTN - hopefully we can either remotely provision them or get replacements! we'll get all the info and figure out asolution!
adafruit2
Site Admin
by djfurie on Wed Nov 18, 2020 12:44 pm
djfurie
by AlanMitchell on Wed Nov 18, 2020 1:20 pm
AlanMitchell wrote:I too am in the same situation with a gateway I just recently received from Adafruit...
I also get the "Not Provisioned" response to the curl command posted previously in this thread.
AlanMitchell
by adafruit2 on Wed Nov 18, 2020 1:21 pm
we've let TTN know and they are looking into it right now
adafruit2
Site Admin
by rish_ttn on Wed Nov 18, 2020 2:04 pm
Hi all, am Rish here from TTN team looking into this issue. Will post an update shortly.
Update - these gateways have been configured to TTN earlier this morning. Can you power cycle the gateway and try again? In case it doesn't work, please drop me a line hardware[at]thethingsindustries.com and I'll help you out.
rish_ttn
by djfurie on Wed Nov 18, 2020 4:21 pm
Hi Rish,
Whatever you did seems to have worked. I'm getting a solid green LED and the gateway status has updated to "Connected" in the TTN console.
djfurie
by AlanMitchell on Wed Nov 18, 2020 4:32 pm
Thank you Rish. Success for mine as well!
AlanMitchell
by aromring on Wed Nov 18, 2020 10:27 pm
Hey, solid green LED for me, too! And the TTN console shows "connected". :) :)
Rish, thank you, but please do tell us: What did you do to fix this? So that we know how to fix this in the future...
aromring
