Thermocouple Data logger
by rfogg on Sat Nov 28, 2020 3:15 pm
I have a NodeMCU ESP8266 and a MAX6675 Thermocouple. I am trying to use Adafruit IO to log temps from my wood stove. I can get the esp8266 and the max6675 to serial print the correct temps and I can get the esp8266 to log data to Adafruit IO, But when I try to combine the 2 my serial print displays
Cut here for exeption decoder
soft wdt reset
Then a bunch of codes. I have no idea what I am doing wrong. I have gone back and used the serial thermocouple example and added code 1 line at a time until everything went wrong the line of code that makes everything go wrong is.
while(io.status() < AIO_CONNECTED)
Any help would be great. Please take it easy on me. I am new to this and really have little knowledge.
rfogg
Re: Thermocouple Data logger
by adafruit_support_bill on Sat Nov 28, 2020 3:24 pm
soft wdt reset
Looks like the watchdog timer is timing out on you.
You probably need to add a 'yield()' to that loop so that it can handle the background processing and keep the watchdog happy while you wait.
https://www.esp8266.com/viewtopic.php?t=16975
by rfogg on Sat Nov 28, 2020 5:08 pm
Thank you very much for the help. I changed the code to
while(io.status() < AIO_CONNECTED) delay(1);
and it worked great.
Thanks again for the help
rfogg
