MQTT With Local Server
by yyjdennis on Sat Nov 28, 2020 8:17 pm
Does anyone have an example of using the Adafruit MQTT library with a local MQTT server? I think I just have to replace the Adafruit IO url with my server's ip address and port, but I must be messing up the syntax somehow.
yyjdennis
Re: MQTT With Local Server
by brubell on Mon Nov 30, 2020 11:29 am
An example for this doesn't exist - we use the Adafruit IO server because it's a reliable server and people don't have to set it up.
I've used this library with a local mosquitto broker before. I do not know what error you're receiving, could you please post your code incl. the output from the serial monitor?
brubell
by matterantimatter on Fri Dec 25, 2020 8:32 am
I'm having a similar problem. I'm trying to connect to a local MQTT server that has no hostname (just port and IP address). When I store the IP address in the secrets.py broker entry, as a string, it appears that the esp32spi's socket module is trying to interpret it as name (it dies on a call to get_host_by_name()).
I've tried placing a tuple of the IP address in the secrets file, and embedding it directly in the code, and that doesn't work either.
I can call the esp.ping() method by IP address, but something in the call stack of the MQTT.connect() method is trying to look up the IP address by name.
matterantimatter
by matterantimatter on Mon Dec 28, 2020 3:12 pm
I figured out my issue. I had missed the
wifi.connect()
statement. It's the wireless equivalent of "did you check the cables?"
matterantimatter
