Read toggle state on-demand or at start up?
by JMJunek on Sun Nov 29, 2020 4:01 pm
I've noticed that upon start up, my device (Huzzah esp8266) doesn't know the initial state of a toggle on AIO. I've been using digital->onMessage(handleMessage); and handleMessage(AdafruitIO_Data *data) but that method obviously only runs when an event on AIO (like a toggle state change) happens. So I have to hit all the toggles after startup to get everything synched, and then it's all working fine from then on. It's there a way to read the state of a toggle on-demand, that I could run at start up?
JMJunek
Re: Read toggle state on-demand or at start up?
by brubell on Mon Nov 30, 2020 11:27 am
Yep! You could use the */get topic (https://io.adafruit.com/api/docs/mqtt.h ... -get-topic).
It seems like you're using the Adafruit IO Arduino library - check out an example of using this topic here: https://github.com/adafruit/Adafruit_IO ... d_read.ino
brubell
by JMJunek on Sun Dec 06, 2020 2:38 pm
Nice! that worked perfectly! Thanks Brent!!
JMJunek
