Huzzah Feeds Limit
Huzzah Feeds Limit
by emrlabs on Sun Dec 06, 2020 12:52 am
I'm having an issue which seems to be a feeds limit on the Huzzah. (Adafruit+ with Arduino IDE)
My application has an RS485 network with many sensors feeding data back to the Huzzah. If I exceed 18 feeds the Huzzah won't connect to Adafruit IO. 18 feeds or less and it connects normally. However with 19 feeds or more in the code the serial monitor posts the Connecting to Adafruit...................................(ad infinitum).
I've seen other posts with the suggestion that MAXSUBSCRIPTIONS in the Adafruit_mqtt.h should be changed but it doesn't seem to affect my situation. Is it possible a MALLOC is silently failing somewhere due to insufficient resources?
Any help would be greatly appreciated.
emrlabs
Re: Huzzah Feeds Limit
by mcwresearch on Sun Jan 03, 2021 9:17 am
I just posted a similar issue here: viewtopic.php?f=56&t=173660 and am finding similar numbers (18-20 feeds) for a huzzah.
mcwresearch
by brubell on Mon Jan 04, 2021 11:45 am
I'm replying over on this thread with the same issue: viewtopic.php?f=56&t=173660 and will lock this thread so we don't have two duplicates.
brubell
