MQTT connection not being recognised in the void loop
by ajayraj1992 on Wed Dec 09, 2020 6:26 am
I am trying to publish MPU 9250 readings in the adafruit io sending the data from ESP 32. The WiFi connection is being established, but the code is not going inside the "if(mqtt.connected())" inside the 'void loop' whereas its going inside the same command inside the 'void setup'. I am sure there is no connection issues because once I change "if(mqtt.connected())" to "while(mqtt.connected())" inside setup, code is going inside while loop continuously.
Why is the code not going inside the if command and how can this be solved?
I also tried using "MQTT_connect()" defined in the adafruit tutorial. It is giving connection failed output.
#include <WiFi.h >
#include <Adafruit_MQTT_Client.h>
#include <MPU9250.h>
#define wifi "********"
#define password "********"
#define server "io.adafruit.com"
#define port 1883
#define username "*******"
#define key "********"
WiFiClient esp;
MPU9250 IMU(Wire,0x68);
Adafruit_MQTT_Client mqtt(&esp,server,port,username,key);
Adafruit_MQTT_Publish feed=Adafruit_MQTT_Publish(&mqtt,username"feeds/accelerodata");
  Serial.begin(115200);
  delay(10);
  Serial.println("Adafruit MQTT Demo");
  Serial.println("Connecting to");
  Serial.println(wifi);
  WiFi.begin(wifi,password);
  while(WiFi.status() != WL_CONNECTED)
    delay(500);
    Serial.println("Connecting...");
  Serial.println("Connected");
  Serial.println("IP Address: ");
  Serial.println(WiFi.localIP());
  Serial.println("Connecting to MQTT");
  if(mqtt.connect())
    Serial.println("MQTT Connected");
void loop ()
  Serial.println("Test line to check if code reaches inside loop");
  delay(1000);
    int data=IMU.getAccelX_mss();
    Serial.println("\nSending accelero data");
    Serial.println(data);
    Serial.println("....");
    if(feed.publish(data))
      Serial.println("Success");
  else
    Serial.println("Fail");
  delay(800);
ajayraj1992
Re: MQTT connection not being recognised in the void loop
by jwcooper on Wed Dec 09, 2020 1:24 pm
I would suggest first trying one of the basic examples from this library and get that to work:
https://github.com/adafruit/Adafruit_IO_Arduino
Then add in your MPU 9250 readings into that example code.
jwcooper
