Feed Filter Bug
Feed Filter Bug
by iethis on Tue Dec 15, 2020 5:02 pm
I have seen this buried in some other topic and reported by a few people and then the subject changed....
Using the date pickers presented on a feed to filter by date range will cause a JS error which leaves the user with a black screen.
The date pickers are (not well supported) rendered by the browser (chrome) when the input type is datetime-local. The key there being local. The rest of the JS is hard coded to a en_us locale.... So I would expect anyone trying to use these filters with a locale that uses a non US format will have this issue.
Needs to retrieve locale and then use code for that locale.
Or, just give us the option to use text input and we can put in the dates in a specified format.
iethis
Re: Feed Filter Bug
by brubell on Wed Dec 16, 2020 11:29 am
Could you please post a screenshot of this error?
brubell
Re: Feed Filter Bug
by iethis on Wed Dec 16, 2020 11:59 am
brubell wrote:Could you please post a screenshot of this error?
sure.
:D
I guess the devtools output is more useful...
iethis
Re: Feed Filter Bug
by brubell on Wed Dec 16, 2020 12:35 pm
Ok, thanks! I've filed a bug report internally for this issue and will update the topic when I have an update.
brubell
Re: Feed Filter Bug
by alexglowee on Tue Mar 30, 2021 8:42 am
Is there an update ? I have exactly the same problem.
alexglowee
Re: Feed Filter Bug
by brubell on Fri Apr 02, 2021 9:23 am
alexglowee wrote:Hi,
No update or ETA, sorry!
brubell
Re: Feed Filter Bug
by alexglowee on Fri Apr 02, 2021 9:44 am
So, currently, there isn't a method to filter the feed?
I wanted to pay for an IO+ account but this option is very important for us :/
alexglowee
Re: Feed Filter Bug
by brubell on Fri Apr 02, 2021 9:54 am
Not from the website, however, you can download the feed's data as .csv and filter in excel, or as .json.
brubell
Re: Feed Filter Bug
by alexglowee on Fri Apr 02, 2021 10:09 am
Of course but if a sensor feed is active 24h/24 and 7D/7 good luck to filter your data to have for example only one hour.
I have already tested this solution and Excel is very slow when there is too much data...
alexglowee
Re: Feed Filter Bug
by adruino on Sun Jun 06, 2021 9:37 pm
Just giving this a bump.
I would like to filter my data and eliminate on spurious value in a few data feeds.
I updated my device firmware and introduced a bug that sent a few obviously bad values which I'd like to delete from the feed.
-Adrian
adruino
Re: Feed Filter Bug
by jwcooper on Tue Jun 15, 2021 11:10 am
We've deployed a change to temporarily remove datetime-local from those inputs. For now, you can edit the date and time as iso8601 date format, which is the default with how those forms should populate.
Eventually, we'll get a proper date widget on there, but wanted to just get a fix out there.
jwcooper
