Feed Filter Bug
iethis
Feed Filter Bug
Post by iethis »
I have seen this buried in some other topic and reported by a few people and then the subject changed....
Using the date pickers presented on a feed to filter by date range will cause a JS error which leaves the user with a black screen.
The date pickers are (not well supported) rendered by the browser (chrome) when the input type is datetime-local. The key there being local. The rest of the JS is hard coded to a en_us locale.... So I would expect anyone trying to use these filters with a locale that uses a non US format will have this issue.
Needs to retrieve locale and then use code for that locale.
Or, just give us the option to use text input and we can put in the dates in a specified format.
brubell
Learn User Page
Re: Feed Filter Bug
Post by brubell »
Could you please post a screenshot of this error?
iethis
Re: Feed Filter Bug
Post by iethis »
brubell wrote:Could you please post a screenshot of this error?
sure.
:D
I guess the devtools output is more useful...
brubell
Learn User Page
Re: Feed Filter Bug
Post by brubell »
Ok, thanks! I've filed a bug report internally for this issue and will update the topic when I have an update.
alexglowee
Re: Feed Filter Bug
Post by alexglowee »
Is there an update ? I have exactly the same problem.
brubell
Learn User Page
Re: Feed Filter Bug
Post by brubell »
alexglowee wrote:Hi,
No update or ETA, sorry!
alexglowee
Re: Feed Filter Bug
So, currently, there isn't a method to filter the feed?
I wanted to pay for an IO+ account but this option is very important for us :/
brubell
Learn User Page
Re: Feed Filter Bug
Post by brubell »
Not from the website, however, you can download the feed's data as .csv and filter in excel, or as .json.
alexglowee
Re: Feed Filter Bug
Of course but if a sensor feed is active 24h/24 and 7D/7 good luck to filter your data to have for example only one hour.
I have already tested this solution and Excel is very slow when there is too much data...
adruino
Re: Feed Filter Bug
Post by adruino »
Just giving this a bump.
I would like to filter my data and eliminate on spurious value in a few data feeds.
I updated my device firmware and introduced a bug that sent a few obviously bad values which I'd like to delete from the feed.
-Adrian
jwcooper
Re: Feed Filter Bug
Post by jwcooper »
We've deployed a change to temporarily remove datetime-local from those inputs. For now, you can edit the date and time as iso8601 date format, which is the default with how those forms should populate.
Eventually, we'll get a proper date widget on there, but wanted to just get a fix out there.
martyburns
Re: Feed Filter Bug
Post by martyburns »
Hi, I am still getting this error, can you please give me an example date format for me to enter?
I have tried yyyy-mm-dd but no luck.
jwcooper
Re: Feed Filter Bug
Post by jwcooper »
It should default to the proper format when you initially click the Filter button. Example here: 2021-08-02T13:06
Make sure to include the time.
It's on our list to add a nicer date picker to that Filter option as well.
kevinjwalters
Re: Feed Filter Bug
Post by kevinjwalters »
I also get the black screen too if I try to filter the feed data even if I leave the values as they appear on the filter. I have a public feed which this can be seen on https://io.adafruit.com/kevinjwalters/f ... 0-standard - just click on Filter then click Apply.
Return to “Internet of Things: Adafruit IO and Wippersnapper”
