Poor online continous service
by raminsoltanzr on Mon Dec 28, 2020 12:50 am
I have been working on this server and first I supposed that it is a very reliable server. Now, after several times of testing, I understood that it is a very crapy service. Even I paid $50 and still, it shuts down my connections. I am 100% sure nothing is wrong on my side and WiFi works perfectly.
raminsoltanzr
Re: Poor online continous service
by brubell on Mon Dec 28, 2020 10:24 am
Hi raminsoltanzr,
I do understand that IoT projects can be frustrating and I'm sorry to hear that you're having issues with your project.
Adafruit IO has had no reported downtime. You can check this for yourself over at https://www.adafruitstatus.com.
Could you please post the exact issue you are having, in as much detail as possible, so I can work through it with you?
brubell
by raminsoltanzr on Tue Dec 29, 2020 11:18 pm
I am monitoring some parameters and every 3 seconds send around 10 data on the portal. It only lasts for 9 hours and after that, the portal kicks out my device! I want to have my device always alive and no interruption between data. What is your advice?
raminsoltanzr
by brubell on Wed Dec 30, 2020 11:18 am
I checked the plan associated with your account, it should be able to send at this data rate.
What hardware (board/device) are you using?
Which libraries are you using to connect to Adafruit IO?
brubell
by raminsoltanzr on Wed Dec 30, 2020 1:19 pm
Thanks for your response. I am using Wipy 3.0 (from pycom series based on ESP32 microcontrollers)
This is the "info" part of the MQTT that I am using. It seems like it is version 1 (I am not sure tho):
#!/usr/bin/env python
# Copyright (c) 2019, Pycom Limited.
# This software is licensed under the GNU GPL version 3 or any
# later version, with permitted additional terms. For more information
# see the Pycom Licence v1.0 document supplied with this file, or
# available at https://www.pycom.io/opensource/licensing
raminsoltanzr
by raminsoltanzr on Wed Dec 30, 2020 1:56 pm
This is the library that I am using (from pycom)
https://github.com/pycom/pycom-librarie ... tt/mqtt.py
raminsoltanzr
by brubell on Mon Jan 04, 2021 11:51 am
This library should be OK - could you please post the code running on your device? Please make sure your code does not include your Adafruit IO Active Key or WiFi network credentials.
brubell
by raminsoltanzr on Mon Jan 04, 2021 1:46 pm
Is it possible that I send them privetly? The code belongs to company and unfortunately, I cannot share it in public. Also, I wrote an OO based code and it is not just one piece of code that I can simpily post it here.
raminsoltanzr
by brubell on Mon Jan 04, 2021 3:42 pm
raminsoltanzr wrote:Is it possible that I send them privetly? The code belongs to company and unfortunately, I cannot share it in public. Also, I wrote an OO based code and it is not just one piece of code that I can simpily post it here.
Sure, submit on https://io.adafruit.com/feedback and include a link to this thread so I know what the ticket is in reference to
brubell
by raminsoltanzr on Fri Jan 08, 2021 12:39 am
Hi
I sent my code on the feedback but I have not heard back from you yet. I appreciate if you help me to have robust communication for an important test. It is very important for me to have a persistent connection and if you think your server cannot handle it, please let me know as soon as possible that I can find another solution.
raminsoltanzr
