Disable text "You are currently in Kiosk Mode"
by litamin on Mon Jan 04, 2021 2:08 pm
Hi, is there anyway to disable the text "You are currently in Kiosk Mode, press ESC to exit" that shows up every time one goes to the kiosk URL?
It often blocks the buttons underneath it until it dissapears after a few seconds, And it doesn't look too slick/pro when you want to show someone else your project, nor can I quite understand the meaning behind it in the first place.
litamin
Re: Disable text "You are currently in Kiosk Mode"
by mikeysklar on Tue Jan 05, 2021 6:51 pm
Can you try using:
 ?kiosk=false
to the Adafruit IO Dashboard URL to disable kiosk mode?
mikeysklar
by litamin on Wed Jan 06, 2021 2:23 pm
I think you misunderstood me; I still want the kiosk mode - I just dont want the ugly text that pops up and says that I am in kiosk mode. It is unnecessary and doesn't look nice.
litamin
by mikeysklar on Wed Jan 06, 2021 4:47 pm
@litamin,
Okay, reverse the previous statement. Does adding this to your URL remove the prompt?
 ?kiosk=true
mikeysklar
by litamin on Thu Jan 07, 2021 3:11 pm
But adding that text is exactly what is enabling the kiosk mode. When you add that to the standard public URL that shows you the standard dashboard, you will get kiosk mode. And sure I have added it because I do want kiosk mode. What I do not want is the pop up saying that I am in kiosk mode.
So to answer your question: yes ?kiosk=true has been there in the end of my public URL all along.
litamin
by brubell on Fri Jan 08, 2021 11:18 am
Could you please take a screenshot of this issue? thanks
brubell
by litamin on Fri Jan 08, 2021 2:09 pm
Sure! Here you can see it - it stays there for about 5 seconds before dissapearing. I'm using chrome. Same on my phone as on my laptop.
As you can see, it not only covers the blocks underneath it, but also (in my opinion) ruins the look and is superflous. Imagine everytime you open an app it says "you are now in full screen mode". :)
Screenshot 2021-01-08 at 19.00.20.png (84.53 KiB) Viewed 61 times
litamin
