Name of Adafruit's modified version of WifiNINA
by ColoradoFrench on Tue Jan 05, 2021 9:36 pm
Hello, in the following (now locked) discussion with @woosley, @brubell explained that Adafruit modified Arduino's WifiNINA library. I am pursuing the same goal of using it with an Arduino Uno Wifi Rev2.
It does not state the name of the new library. What is it? Links?
https://forums.adafruit.com/viewtopic.php?f=56&t=151834
ColoradoFrench
Re: Name of Adafruit's modified version of WifiNINA
by brubell on Wed Jan 06, 2021 11:57 am
brubell
by ColoradoFrench on Wed Jan 06, 2021 11:41 pm
Thanks @brubell
So is it the case that it's a different library by the same name (or fork of the main one)? If so, do I actually need to uninstall the one from the IDE and manually install this one?
If so, it's hard to see this as a sustainable distribution mechanism.
ColoradoFrench
by brubell on Fri Jan 08, 2021 11:16 am
Uninstall the one from the IDE and install this one manually. We haven't formally packaged the adafruit fork for distribution via the arduino library manager.
brubell
by ColoradoFrench on Fri Jan 08, 2021 12:51 pm
Ok, I will. However I regret that this was not packaged formally and properly documented, and I recommend that should be done ASAP.
Thank you
ColoradoFrench
